> 14-inch Fuchs Wheels and Tires Combo, Please share your tire size and photos
DennisV
post Jun 4 2023, 09:34 AM
I would appreciate it if folks who have 14-inch Fuchs wheels could share photos of them on the car along with their tire size.
Our 1970 914-6 has what appear to be authentic Fuchs 5 1/2 J 14. I believe these were an original factory option. Trying to decide on tires. The manual and sticker on the car only indicates "185 HR 14". So no sidewall height is indicated.
I know there are lots of tire threads. I've been poking around the forum and I've seen listed everything from "185/70/14 was the OEM size" to "82 if they were measured like today's tires".
Vredestein Sprint Classic would seem like an easy choice, but they are out of stock everywhere I have looked.
Ultimately I guess I'm going to be stuck with what's available today and making an aesthetic choice. It will be spirited street driving in California, so I don't need to worry about all-weather or track demands. What's on the car now is 195/70R14 90R - Riken Radial 70 Steel Belted. Not a great photo as it's on a lift and the engine is out. I would normally run with a bit higher air pressure. (IMG:style_emoticons/default/smash.gif)
Replies(1 - 19)
sixnotfour
post Jun 4 2023, 09:54 AM
Best thing I did to MySix, was 15x6 Fuchs in 1978..
Superhawk996
post Jun 4 2023, 10:05 AM
I’d be looking at 185/60/r14 which was a common tire for the 1st gen, North American miata.
Miatas of that era were on 5.5” rims
Used to be lots of good choices but not sure how it is in 2023. Offered plenty of grip and footprint for a 2000 lb car without the disadvantage of going to larger rims and adding rotational inertia and unsprung mass.
Craigers17
post Jun 4 2023, 10:17 AM
I don't have Fuchs, but I just purchased some 14 inch wheels that I am going to put on my 914. I don't have pics of them on the car because I need to refinish them first, but I am going with Falken Azenis RT615K+. 195/60/14
They are performance tires, but that doesn't seem to be an issue based on what you've said. I bought these because they have been around awhile and have pretty decent ratings.....I also like the way the tire looks. Here's a link:
https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes
Superhawk996
post Jun 4 2023, 10:35 AM
I just took a quick look and there are still some decent options for 14” but a whole lot less than there used to be. Options still range from high mileage all seasons that are going to lack grip to high grip Toyo Proxies for auto crossing that will sand blast your rocker panels because they pick up so much road debris.
Modern cars have moved to clown size wheels and tires. That may be great for 2 1/2 ton lead sleds that needed big brakes and have plenty of HP and torque courtesy of modern powerplants. However, large wheels and tires just sap acceleration and drive up spring rates, and damping which degrade ride quality.
I’ve long been a fan of 14” and 15” wheels which seem to me to be the sweet spot for 914s. I think you are wise to stay with the 14” Fuchs - not many of those floating around anymore. Cool original wheels that often got dumped in the rush to American’s bigger is better fixation.
brant
post Jun 4 2023, 11:44 AM
The beauty of a 14 inch Fuchs is that the car was designed around that tire
It has the second best offsets of all of the Porsche wheels for a 914
(Closest offset to a 7R wheel)
So you can fit a slightly wider tire
I have a set with 215/14 tires mounted
That fit under stock fenders
Although I use them for trailer wheels now
To get the ride height needed for loading the car in/out of the trailer
DennisV
post Jun 4 2023, 12:46 PM
QUOTE(Craigers17 @ Jun 4 2023, 09:17 AM) *
Thanks for the link. They seem reasonably priced, well rated tires. I wonder how well a 60 profile would look in the 914 wheel well. Thus my request for photos.
To my surprise, the difference in 60 vs 80 profile throws off the speedometer about 7 mph?!
zoomCat
post Jun 4 2023, 01:46 PM
QUOTE(DennisV @ Jun 4 2023, 02:46 PM) *
If speedometer accuracy is a concern at all then you need to compare the tread diameter. This page from the service manual neglects the 15” alloy rim that also was optional, that ran 185/70 15 tires with a diameter of 25.2.
brant
post Jun 4 2023, 02:19 PM
You’ll need to go with a tall profile if you want speedometer accuracy
Or recalibrate the speedometer
gandalf_025
post Jun 4 2023, 03:13 PM
I have Riken 185-60-14’s on my car.
Don’t know if they still make them..
Used them on an early 911 mostly.
This tire is under inflated and the ride height
is wrong so this may not be a good picture to compare..??
DennisV
post Jun 4 2023, 03:21 PM
QUOTE(gandalf_025 @ Jun 4 2023, 02:13 PM) *
Very helpful. The framing in the wheel well is noticeable different to me. Not bad. Just different. Thank you!
DennisV
post Jun 4 2023, 03:24 PM
QUOTE(zoomCat @ Jun 4 2023, 12:46 PM) *
Thank you for pointing that out. I had overlooked this table. The Coker website will let you filter on radial width among other things.
live free & drive
post Jun 4 2023, 04:51 PM
I have these on an Alfa and can confirm that they are an excellent tire - they are also just about the right OD for your 914:
https://lucasclassictires.com/185-70VR14-PI...-1857014Pir.htm
maxwelj
post Jun 4 2023, 04:56 PM
rebuilt member
These are Dunlop 195/60
DennisV
post Jun 4 2023, 06:05 PM
QUOTE(live free & drive @ Jun 4 2023, 03:51 PM) *
I had never even heard of this place or seen that tire. Thanks for the link!
Superhawk996
post Jun 4 2023, 06:07 PM
QUOTE(DennisV @ Jun 4 2023, 08:05 PM) *
That does look interesting.
DennisV
post Jun 5 2023, 09:50 AM
Maybe it was obvious to others, but I was fishing for the aspect ratio of the side wall for the original tires. Thanks to the table from @zoomCat and a tire size calculator factoring in the wheel size, I think the closest modern day equivalent is:
185/80R14.
This lands you at: Tire Height: 25.66'' (652 mm)
Anyone got that combo they can share a photo of? It is about 1/2" difference in sidewall height from what we have now.
I wonder how wide you can safely go on those rims. It read somewhere that 165 - 195 works?
How unique is the "J" wheel collar (i.e. tire bead) profile? Does that become a special tire choice?
live free & drive
post Jun 5 2023, 04:53 PM
These will get you to 25.6" diameter:
https://www.cokertire.com/tires/185hr14-michelin-mxv-p.html
Racer
post Jun 6 2023, 12:15 PM
QUOTE(DennisV @ Jun 5 2023, 11:50 AM) *
185/80R14.
Correct. Back then they didn't put an aspect ratio and as others have mentioned, its close to an 80 series tire.
our 914/6 has been in the family since new, with 5.5x14 Fuchs the whole time (and occasionally 6x15 cookie cutters). In period (1970-1990s) - Michelin XWX tires!
185/14s
185/70 14
195/70 14
205/70-14 - a little balloonish, but they fit in period with some rolled fenderlips
Period 15" wheels (15 inch steel was standard.. 5.5x15 that is, or, 6x15 911 fuchs) have run over the years 165/80-15, 185/70-15 and for autocross, 195/50 and, 195/60)
I've been running the Falken Azenis 615s in 195/60-14 since 2016 on a warm weather use car (often at Autocross) on my 5.5x14s. They wear well, they grip well and are also a quiet tire.
I'd upload pics but, it never works for me. They are a little "short" compared to a 70 series tire, but that's ok with me.
Speedometer? who cares.. its a 50 year old car with 110hp.. its not powerful enough to get caught speeding (IMG:style_emoticons/default/wink.gif) I can do math quickly.. and figure 7-10% high. I know others out here are caught out by these transgressions (IMG:style_emoticons/default/wink.gif)
Nowadays it comes down to what is available... and for 14" wheels, the choices are pretty slim, especially if you want some "performance".
DennisV
post Jun 12 2023, 02:19 PM
A couple of recent BAT auctions served up a direct comparison on nearly identical cars. (IMG:style_emoticons/default/piratenanner.gif)
9 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
4 Members: sburns1967, MikeK, 913B, sb914
- Lo-Fi Version Time is now: 15th July 2026 - 02:22 PM
