| Stef914 |
Jun 6 2023, 07:41 PM
human ![]() ![]() Group: Members Posts: 105 Joined: 21-July 21 From: Los Angeles Member No.: 25,745 Region Association: Southern California |
Does anyone have this installed in their 914 ?
https://www.h3rperformance.com/collections/...sher-seat-mount Looks like @pvollma has it on but it's not specified how it gets installed ... http://www.914world.com/bbs2/index.php?sho...p;#entry1961034 Would otherwise anyone know of alternative fire extinguisher mounts that actually fits under and in the front side of the passenger seat without having to do custom mods ? Thanks ! |
| windforfun |
Jun 6 2023, 09:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,097 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
I don't like any non-stock modifications. I'm old fashioned I guess. I put my FE in a thick wool hiking boot sock & stick it behind the passenger seat. The seat moves easily so the FE is easy to get to. It doesn't move since the seat is almost all the way back. Whatever. Enjoy your evening.
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
| mb911 |
Jun 7 2023, 04:44 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,729 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I made a simple one for my car that didn’t modify the car
| 930cabman |
Jun 7 2023, 05:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I found a simple bracket on Amazon, screwed it to a small piece of 1/2" plywood and it lives on the passenger floor somewhat tucked under the seat. Cheap, effective, easy
| StarBear |
Jun 7 2023, 05:28 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,259 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
I found a simple bracket on Amazon, screwed it to a small piece of 1/2" plywood and it lives on the passenger floor somewhat tucked under the seat. Cheap, effective, easy Me, too. Added two strips of the “hook” side of adhesive Velcro to back of the wood so the unit doesn’t slide around. |
| 930cabman |
Jun 7 2023, 11:57 AM
I found a simple bracket on Amazon, screwed it to a small piece of 1/2" plywood and it lives on the passenger floor somewhat tucked under the seat. Cheap, effective, easy Me, too. Added two strips of the “hook” side of adhesive Velcro to back of the wood so the unit doesn’t slide around. "so it doesn't slide around" how many G's are you cornering these days? Mine just lays there and hasn't moved a bit, but I am running narrow tires (IMG:style_emoticons/default/aktion035.gif) |
| DC_neun_vierzehn |
Jun 7 2023, 12:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 640 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
Does anyone have this installed in their 914 ? https://www.h3rperformance.com/collections/...sher-seat-mount Looks like @pvollma has it on but it's not specified how it gets installed ... http://www.914world.com/bbs2/index.php?sho...p;#entry1961034 Would otherwise anyone know of alternative fire extinguisher mounts that actually fits under and in the front side of the passenger seat without having to do custom mods ? Thanks ! I have this one. I was able to secure one side of the bracket on one of the seat rails (b/t the seat rail and the bottom of the seat). I believe I had to get slightly longer bolts to accommodate that extra thickness. I intend to go back and fab something up that would serve as an extension to allow the other side to reach the other seat rail on the bottom of the seat, but I haven't gotten to it yet. It's pretty secure with just the one side bolted in, but I want it to be symmetrical and fully secure. |
| 930cabman |
Jun 7 2023, 12:14 PM
I have used this one: https://www.amazon.com/gp/product/B009YO2HS...=UTF8&psc=1
screwed to a piece of 1/2" plywood, sits on the floor partially under the passenger seat. No fasteners required, hasn't moved at all. the friction between the "rough" plywood and carpeting holds tight. |
| 914werke |
Jun 7 2023, 01:40 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,606 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
| mgphoto |
Jun 7 2023, 02:29 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
| 914werke |
Jun 7 2023, 02:34 PM
| StarBear |
Jun 7 2023, 02:48 PM
I found a simple bracket on Amazon, screwed it to a small piece of 1/2" plywood and it lives on the passenger floor somewhat tucked under the seat. Cheap, effective, easy Me, too. Added two strips of the “hook” side of adhesive Velcro to back of the wood so the unit doesn’t slide around. "so it doesn't slide around" how many G's are you cornering these days? Mine just lays there and hasn't moved a bit, but I am running narrow tires (IMG:style_emoticons/default/aktion035.gif) Oh, my board has a smooth finish. Should roughen that bottom. |
| eric9144 |
Jun 7 2023, 03:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,794 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California
| StarBear |
Jun 7 2023, 03:14 PM
@Stef914
Here’s my hobo setup. Pics below. 5lb Purple unit. I think I’ll replace the board with one that has a rougher bottom and is longer to extend past handle and bottom. ![]() |
| DC_neun_vierzehn |
Jun 7 2023, 05:15 PM
@CHIZ 914 Nice mount. Do tell ... how much for one of these? |
| Type 47 |
Jun 7 2023, 07:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 796 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None
I don't like any non-stock modifications. I'm old fashioned I guess. I put my FE in a thick wool hiking boot sock & stick it behind the passenger seat. The seat moves easily so the FE is easy to get to. It doesn't move since the seat is almost all the way back. Whatever. Enjoy your evening. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) I'm sure Paul Walker was saying "yeah I'm glad there's not a modded, not stock fire extinguisher in this Carrara GT, let's go. Of course, a torched 914 from a fuel line fire would be old fashioned, just like many back in the day. Sorry, but your solution requires frequent drills to remove the FE from the HBS or it may be worthless. Say you put the FE in the HBS behind the PS and a fuel line fire, battery side, errupts. You freak and amaze at the size of the fireball. You reach over to the PS adjuster and try to move it up the get to the HBS. But b/c your not in the seat you can't make it move. That impressive ball of fire is now getting ready to explode. It's at this point you realize you are going to die just like Paul Wlker because you didn't like any stock modifications. ALL 914's need a quickly accessible FE! |
| bkrantz |
Jun 7 2023, 07:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I glued a strip of plywood to the floor under the carpet, and then screwed the stock extinguisher bracket into that.
Attached thumbnail(s) |
| bkrantz |
Jun 7 2023, 07:43 PM
And this
| bkrantz |
Jun 7 2023, 07:44 PM
For this
| 914werke |
Jun 8 2023, 12:05 AM
It's a Brey-Krause mount.
Lo-Fi Version | Time is now: 2nd April 2026 - 01:25 PM |
