44IDF unresponsive idle mixture screws |
3liter914-6 |
Jun 11 2023, 05:42 PM
Master of Clueless Posts Group: Benefactors Posts: 310 Joined: 12-October 03 From: State College, PA Member No.: 1,238 Region Association: MidAtlantic Region |
Hi folks,
My brother's 914 has been sitting for a decade or so ever since I installed a 2270 for him to replace the stock 2L he blew'd up. Being the good brother I am I recently decided to actually install most of the parts I've been secretly buying for him over the years and after a bit of work and a lot of money on Webers and digital distributors and a fancy Tangerine racing cable linkage it's shaken off its cobwebs and is now up and running. It fires up pretty nicely, but it's a bit rough running with some popping. I disconnected the linkage and went through the adjustment procedure per Weber's lean best idle procedure. Everything goes well until I get to the idle mixture screws where nothing really happens. Google searches tell me this is caused by 3 things: 1. Vacuum leaks I've sprayed ether at the manifold base and at the carb/manifold interface without noticeable change, so this leads me to believe it's not the issue 2. Dirty idle jets/circuit. I just rebuilt the carbs, even though after opening them up it seemed unnecessary. Gave them a 24 hour soak followed by blasting out every orifice and jet I could find with carb cleaner and compressed air. So I'm not inclined to think this is the issue. Arguing against the above is that this is on all 4 carb barrels, if it were a leak or clog I would think there would be some affected/unaffected. 3. Incorrectly sized idle jet. This could make sense given that they all have the same jet and all cylinders are affected. Per the stamping they're 55s which more or less seems to be the accepted default 44IDF jet size, so it's surprising to me that would be far enough off in size to be totally unresponsive. Any other troubleshooting I can attempt that might help answer the question of do I need different (larger?) idle jets? Anything I'm missing? Thanks! |
Superhawk996 |
Jun 11 2023, 05:49 PM
914 Guru Group: Members Posts: 5,884 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
#4 air bypass screws open too far.
It basically is a vacuum leak (item #1) but the “leak” is entirely self contained within the carb. |
3liter914-6 |
Jun 11 2023, 05:59 PM
#4 air bypass screws open too far. It basically is a vacuum leak (item #1) but the “leak” is entirely self contained within the carb. Good thought. I have those all the way in and locked down with the jam nut if I'm thinking about the right ones. I'm gonna head out and pull the idle jets just in case they all plugged, but they're behind a 10 micron filter so I wouldn't expect that. |
Superhawk996 |
Jun 11 2023, 06:05 PM
#4 air bypass screws open too far. It basically is a vacuum leak (item #1) but the “leak” is entirely self contained within the carb. Good thought. I have those all the way in and locked down with the jam nut if I'm thinking about the right ones. I'm gonna head out and pull the idle jets just in case they all plugged, but they're behind a 10 micron filter so I wouldn't expect that. Blockage in jet passages can occur from corrosion - if there is any doubt, pull the carbs and clean all passages. The other thing that will keep the idle mix screws from being responsive is trying to tune with the throttle plates open too far - idle speed screw controlling the butterfly ought to be about 1/2 turn max. Throttle butterfly should be covering all of the transition port holes. Also if you’re not familiar with tuning - slow is the name of the game. Changes to idle mix screws take some time to affect engine speed. |
rhodyguy |
Jun 11 2023, 07:41 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Popping…out the exhaust or snapping back thru the carbs?
rfinegan |
Jun 12 2023, 02:08 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
If your screws are unresponsive, your idle circuit is plugged or your throttle plate is open to far and off the idle circuit and into the transitions slots
Lo-Fi Version | Time is now: 4th June 2024 - 05:28 AM |
