> Any of you 6 guys added a valve for oil tank draining?
peteinjp
post Jun 13 2023, 10:31 PM
Its not a huge deal to separate the hoses but if changing the oil often it would be nice to plumb in a valve or some type of plug to reduce long term wear on the hose seal. Anyone done this? Or any other thoughts?
Pete
3 Pages V  1 2 3 >
Replies(1 - 19)
mlindner
post Jun 14 2023, 04:34 AM
Hi Pete. I fabricated a 90 deg fitting for the oil line so it would not kink when using the oil drain back device. If I make another one I will incorporate a drain plug in it. Best, MarkAttached Image
peteinjp
post Jun 14 2023, 05:41 AM
So you just cut the stock hose to make that correct? What does a check valve do for you?
mate914
post Jun 14 2023, 06:26 AM
Matt
Some off the 6 engines need a check valve to stop oil from the tank emptying into engine (lots of smoke upon start up).
Matt (IMG:style_emoticons/default/flag.gif)
QUOTE(peteinjp @ Jun 14 2023, 07:41 AM) *
Cairo94507
post Jun 14 2023, 07:27 AM
Michael
Not going to lie, I would like to add a drain valve into the tank line to make oil changes quicker and easier. Just need to remember to safety wire it after you close it. (IMG:style_emoticons/default/beerchug.gif)
914dave
post Jun 14 2023, 07:40 AM
914 Addict
i have the parts to do this. My plumbing is braided stainless. I plan on adding it between the tank and the engine on the frame behind the trailing arm. I'm working on the safety wire setup.
Steve
post Jun 14 2023, 07:46 AM
I don't have a picture handy, but I have a an-16 male welded on the oil engine oil cooler and a an-16 adapter on the bottom of the tank. This allowed me to install a an-16 "T" with a cap in the oil line. Very easy to change the oil with this setup. Don't have to disconnect any hoses. I have seen somebody in the past install a valve in this line, which is easier than removing the AN-16 cap.
Biggles
post Jun 14 2023, 08:06 AM
Region Association: England
Definitely recommend doing this in terms of the time saving and preventing the risk of putting any stress on the weld to the engine oil coller in removing the pipes (which was my previous experience).
Mine's a 3.2 with a termostat to the front cooler, but pics show the old set up (with annotations) and new set up with the 3 way ball valve installed (threaded brass plug to the drain hole is not shown as fitted in photo but obv. should be) on the line to the engine cooler. Only issue too with a front oil cooler, as per this set up, is that you can never fully drain the system towards the front, not an issue with regular oil changes.
Steve
post Jun 14 2023, 08:40 AM
QUOTE(Biggles @ Jun 14 2023, 07:06 AM) *
That is a nice setup!! Where did you find/purchase the valve and "T" from? It's much cleaner than my AN16 "T" and cap.
Krieger
post Jun 14 2023, 09:28 AM
I put it on the union for the two oil lines. It works very well and was easy to do. OEM lines and tank on a conversion car.
I had a machinist drill hole and face the surface so it was flat.
fixer34
post Jun 14 2023, 09:32 AM
QUOTE(peteinjp @ Jun 14 2023, 06:41 AM) *
It's been 6 years since I put 1000 miles on my -6, plus I did almost a full drain when I installed a check valve a couple years ago. Doing regular oil changes by disconnecting a hose is not an issue right now.
On a -6 that isn't driven often, the oil in the tank can seep back into the engine sump. If all the seals are tight, it can fill to the point where oil leaks past the rings and you get a lot of blue smoke when starting. In extreme cases, it fills the case to the point where the engine won't start.
With mine, I have a leak somewhere that lets the oil in the case drip onto the garage floor when it gets too full, to the point I used to lose 2-3 quarts over several months. That is why I went with a Rothsport check valve. I still get a leak, but it is on the order of a few tablespoons over a couple months now. 'Some day' I'll fix it, just need to figure out when the some day will be.
fixer34
post Jun 14 2023, 09:34 AM
QUOTE(Krieger @ Jun 14 2023, 10:28 AM) *
I had a machinist face the surface.
This looks like a group buy item...
Root_Werks
post Jun 14 2023, 10:19 AM
Village Idiot
QUOTE(Krieger @ Jun 14 2023, 08:28 AM) *
I really like that! Running stock 914-6 lines and will do the same. Neat idea!
johnhora
post Jun 14 2023, 10:26 AM
Very clever..
Nice solution...just put in-between the existing stock lines
OK...who's going to make these (IMG:style_emoticons/default/biggrin.gif)
@mb911
@Mikey914
Lucky9146
post Jun 14 2023, 10:43 AM
Good thread. Unfortunately I did not include a tank drain and have little real estate available to do so for my 6 conversion. This thread will help get me going on re-evaluating my set up. Thanks!
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg)
BillJ
I would take two immediately. An -12
Biggles
post Jun 14 2023, 10:45 AM
QUOTE(Steve @ Jun 14 2023, 03:40 PM) *
Steve. I had some engine work done and the garage did this at the same time. Just google 3 way ball valve. That'll give a good starting point. Dont think its anything special.
mb911
post Jun 14 2023, 12:45 PM
I could do them very easily. I have a hundred 30mm fittings still
porschetub
post Jun 14 2023, 01:37 PM
QUOTE(peteinjp @ Jun 14 2023, 05:31 PM) *
Pete
Where the hoses join with the male/male union I drilled a hole and threaded it for a plug as appears many have done (my late reply ) ,not keen on using a valve,works pretty well but in reality you don't always get 100% of the old but if you change oil to the right schedule its really not an issue .
Steve
post Jun 14 2023, 02:25 PM
QUOTE(porschetub @ Jun 14 2023, 12:37 PM) *
Pete
Where the hoses join with the male/male union I drilled a hole and threaded it for a plug ,not keen on using a valve,works pretty well .
I looked around at the 3 way ball valves and they were only rated for 215 degrees.
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 09:20 AM
