Bad Voltage Regulator |
Aerostatwv |
Jun 18 2023, 08:24 PM
Member Group: Members Posts: 117 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
Ran across an interesting issue with trying to get a steady idle on my 1.7 d-jet. I purchased a voltage gage that plugs into the cigarette lighter out of curiosity. When the car was idling, the voltage would vary wildly between 13 and 17 volts. Thinking the gage was bad, I tested it on a different car and it held a steady 14 volts. So, I grabbed a spare voltage regulator and bingo, the voltage runs a consistent 13 volts. It leveled out the idle and the car is running much better and now has a smooth idle. Just another datapoint to check for when trying to track down an inconsistent idle.
Chris |
914Sixer |
Jun 19 2023, 06:05 AM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Good information to pass along. Just curious if it was a Bosch unit?
Aerostatwv |
Jun 19 2023, 04:52 PM
914Sixer |
Jun 21 2023, 05:58 AM
Seeing rust, might be the root of the problem.
Lo-Fi Version | Time is now: 28th May 2024 - 11:19 PM |
