1.7 Throttle Return Spring Q |
shredtherad |
Jun 21 2023, 08:40 AM
Member Group: Members Posts: 86 Joined: 17-May 22 From: Longmont, Colorado Member No.: 26,559 Region Association: Rocky Mountains |
my throttle return spring came unattached, simple enough but i am unsure what the best configuration/connection point is for attaching it to the throttle and then to the tin or whatever. Can you critique my work? see photo.
Attached thumbnail(s) |
ClayPerrine |
Jun 21 2023, 09:07 AM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That is not the correct location. There is a small hole in the top of the rear engine tin on the left side for the spring anchor. If you run your fingers along the top of the rear tin, you will feel the hole. It is usually covered by the seal.
Shivers |
Jun 21 2023, 09:23 AM
Senior Member Group: Members Posts: 2,408 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
shredtherad |
Jun 21 2023, 10:22 AM
Drex |
Jun 21 2023, 01:52 PM
Member Group: Members Posts: 170 Joined: 1-December 22 From: Guthrie Center, Iowa Member No.: 27,003 Region Association: None |
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1687377174.1.jpg)
here is the spring set up on my parts 914 hope this helps D Rex |
Lo-Fi Version | Time is now: 31st May 2024 - 10:18 PM |
