Car never ran better - THEN!, Seems when hot there is no low end power |
ctc911ctc |
Jun 25 2023, 04:30 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
'74 2.0 - 25K miles
It has been a very long journey. I, with my 17yr old son who is now 21, rebuilt nearly every system including the Engine and Transmission (a nod to Dr. Evil !! ). My son and I have learned a great deal, however, this one has me stumped. The car runs terrific and is strong, smooth and a joy to drive, today I took it around the Lakes here in Arlington MA and at the end of the drive there is a hill with a red light - I caught the red. I waited as the button pushers jaywalked (after they hit the button) and then I waited some more with the crosswalk signs blinking and no one crossing.....sigh OK, there is the green and I ease out the clutch and apply a little gas AND nothing...... nearly idling. I then bury the gas and the car stalls.......and since this is New England everyone starts beeping and yelling - so I get the flashers on and people go around me. I wait another light cycle and get the cars started by pumping the gas and keeping it running over 1500, once it started moving it ran fine. It is almost as if there was zero power below 1500, though when the car was rolling everything worked as you would expect. When the car is cold the low power is as normal as a 90HP engine can be. The temp of the car is about 2/3rds deflection of the center console temp gauge. I am thinking all sorts of complicated thoughts.......head temp sensor is sending weird signals to the Bosch controller OR when super hot the vacuum system starts leaking, etc. So, I thought I would start here - any ideas teeners???? Keep me sane and guide me to the light! CTC911CTC |
emerygt350 |
Jun 25 2023, 05:55 PM
Advanced Member Group: Members Posts: 2,131 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Do you still have the original distributor?
r_towle |
Jun 25 2023, 06:09 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Advance plates sticking in distributor
Fuel pump needs replacing Head temp sensor is toast Check all grounds |
r_towle |
Jun 25 2023, 06:13 PM
What location did you put the fuel pump?
If it’s in the engine bay, make sure the heat exchanger is not blowing air on the fuel pump |
burton73 |
Jun 25 2023, 06:23 PM
burton73 Group: Members Posts: 3,538 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
http://www.914world.com/bbs2/index.php?showtopic=295025
read up on vapor locking. search with google and as any question and 914world and it will bring up examples That works for me Bob B |
SirAndy |
Jun 25 2023, 06:24 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Car never ran better Back in my dirt bike racing days, that was a sure sign that something was about to go kaputt. They always seemed to run "better than ever" right before failing in a spectacular way. (IMG:style_emoticons/default/popcorn[1].gif) |
ctc911ctc |
Jun 25 2023, 06:27 PM
Ain't it the way!
ctc911ctc |
Jun 25 2023, 06:30 PM
Vapor Lock did not occur to me - the pump is in the same place as stock - I move it a bit to make it "out of the way", will take a look at it.....
Would Vapor lock at the fuel pump result in a reduction in pressure at the rail? If so would this persist once the engine was running at higher RPMs? What location did you put the fuel pump? If it’s in the engine bay, make sure the heat exchanger is not blowing air on the fuel pump |
ctc911ctc |
Jun 25 2023, 06:33 PM
I took the plates out, cleaned and rebuilt the entire assembly - tried to find a new one, however, could not find one for a stock Injector setup......
Will look within the board, Would be nice to have a spare - also, do you think it would be heat sensitive? The advance plates once I was finished were pretty slick, the springs very taught and new Advance plates sticking in distributor Fuel pump needs replacing Head temp sensor is toast Check all grounds |
ctc911ctc |
Jun 25 2023, 06:35 PM
r_towle |
Jun 25 2023, 07:14 PM
Well, fuel and ignition
Can you reproduce the problem , near home? I’m thinking hot coil, or hot fuel pump |
ctc911ctc |
Jun 25 2023, 07:25 PM
r_towle |
Jun 25 2023, 09:04 PM
If you need anything, give me a ring.
Rich |
rjames |
Jun 25 2023, 10:41 PM
I'm made of metal Group: Members Posts: 3,948 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Unlikely it’s your issue, but one summer my car would run great and then stall intermittently after it warmed up. Sometimes I could drive for hours before it would happen, sometimes 30 minutes or less. I’d have to keep the RPMs up to keep it from stalling. Sometimes it would stall anyway.
Turned out the computer was bad. Likely a failing solder joint that would worsen with heat. Intermittent issues are the worst. |
emerygt350 |
Jun 26 2023, 03:43 AM
Can't say enough about the 123dizzy. However it sounds like you have yours in good shape.
The fact it is low rpm really makes me lean that way. You say runs fine over 1500 but does it really? I have had bad coils on other cars behave like that, at higher rpm it was harder to notice, normally that results in bucking at low rpm cruise though. I really don't think this is a vapor lock. |
Cairo94507 |
Jun 26 2023, 06:30 AM
Michael Group: Members Posts: 9,808 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
On a hill and stopped for a long time... how much gas was in the tank? (IMG:style_emoticons/default/beerchug.gif)
76-914 |
Jun 26 2023, 07:52 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Vapor Lock did not occur to me - the pump is in the same place as stock - I move it a bit to make it "out of the way", will take a look at it..... Would Vapor lock at the fuel pump result in a reduction in pressure at the rail? If so would this persist once the engine was running at higher RPMs? What location did you put the fuel pump? If it’s in the engine bay, make sure the heat exchanger is not blowing air on the fuel pump Absolutely. It's very difficult to pressurize a vapor as compared to a liquid. The vapor lock occurs in the pump or in the incoming line. I vaporized upon takeoff and almost shit in my pants. I had been on the tarmac for awhile and it was a hot day.Twenty feet off the runway it began sputtering so I had to slam the plane back down on the runway and full brakes before I ran out of runway! I was running auto gas and it vaporizes quite easily compared to AvGas. (IMG:style_emoticons/default/beerchug.gif) |
ctc911ctc |
Jun 26 2023, 09:18 AM
Yes, my mind did go there - the tank was completely rebuilt with new sending unit, sock, filter and at the time of the stalling was reading over 1/2 tank.
On a hill and stopped for a long time... how much gas was in the tank? (IMG:style_emoticons/default/beerchug.gif) |
emerygt350 |
Jun 26 2023, 03:21 PM
That gets worse with load/rpm. This apparently works fine with load/rpm.
ctc911ctc |
Jun 27 2023, 01:13 PM
Conscious that makes Sens-ous is that the fuel pump is getting too hot and the machine is getting the vapors.......will move the fuel pump or re-route this weekend and report
Lo-Fi Version | Time is now: 1st June 2024 - 01:45 AM |
