Leaking oil, pump |
Leaking oil, pump |
930cabman |
Jul 16 2023, 05:15 PM
Advanced Member Group: Members Posts: 3,166 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Fresh 2056 (2022) engine is running well, but a pesky oil leak has been a down side from day one. Need to be careful if parking at a friends (or enemies) driveway. I don't have 100% cure, but I have isolated it to the front seal/oil pump area over the past couple weeks. I was determined to find it this weekend and removed the engine bar, propped the engine up with a 4x4 and warmed her up good. It took awhile (170 ish oil temp) to get a leak going, but the studs/nuts holding the oil pump cover were leaking. The front seal area looks great, the gasket(s) between the oil pump/case and oil pump/cover look good also. Hopefully new sealing washers and sealing nuts will get things dried up.
bkrantz |
Jul 16 2023, 07:51 PM
914 Guru Group: Members Posts: 7,805 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Good luck. Oil leaks on the front of the case (or anywhere) can be very stubborn and annoying.
Superhawk996 |
Jul 16 2023, 08:17 PM
914 Guru Group: Members Posts: 5,905 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
T1 pump?
930cabman |
Jul 17 2023, 05:03 AM
930cabman |
Jul 17 2023, 05:04 AM
Geezer914 |
Jul 17 2023, 07:55 AM
Geezer914 Group: Members Posts: 1,448 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I smeared some "The Right Stuff" on the back of the nuts and a little on the threads. No leaks.
rfinegan |
Jul 17 2023, 09:44 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
VW Oil Pump Cover Plate Sealing Nut - 8mm
https://www.jbugs.com/product/111115161.htm...soaArqHEALw_wcB These worked well on the T-1 30mm pump and put them on my t4 pump too |
930cabman |
Jul 17 2023, 12:04 PM
VW Oil Pump Cover Plate Sealing Nut - 8mm https://www.jbugs.com/product/111115161.htm...soaArqHEALw_wcB These worked well on the T-1 30mm pump and put them on my t4 pump too Got em, they are on the way. Along with a soft (crush) washer, it should do the trick |
bkrantz |
Jul 17 2023, 07:52 PM
VW Oil Pump Cover Plate Sealing Nut - 8mm https://www.jbugs.com/product/111115161.htm...soaArqHEALw_wcB These worked well on the T-1 30mm pump and put them on my t4 pump too Got em, they are on the way. Along with a soft (crush) washer, it should do the trick I would suggest the sealing nuts without washers--on mine the nuts have sealed without problems. But they are single use. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:08 PM |
