Inconsistent voltage, Not very electrifying |
iankarr |
Jul 24 2023, 10:09 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
Trying to sort through a puzzling situation. My car started bucking like a bronco(D-jet) and I noticed that the voltage was super low (like 10). I fortunately made it home. Changed out the voltage regulator with one I had in my bin and everything seemed to be fine. 13.5 when running, no more bucking. Now I'm seeing that the voltage is inconsistent again. Sometimes it's 13.5 when running, then it dips to around 12, then comes back up. Occasionally the red light will come on for a few seconds, even when running at 3K rpm. When I put the headlights on, the idle drops by 500rpm and stumbles. The belt is tight and the alternator was (supposedly) rebuilt recently. Anyway...my thinking is it can only be one of four things: – Bulb in the cluster (unlikely, but possible). I believe it's stock. – Voltage regulator – Alternator – Battery Do you guys have any simple tests i can run to eliminate any of the above before I just start throwing parts at this? Other thoughts? Thanks! |
StarBear |
Jul 24 2023, 10:32 AM
Senior Member Group: Members Posts: 1,905 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
A loose chassis ground connection? Maybe but fell off so wire connector jiggles on the post? That’s what happened at my trans ground a few weeks ago.
SirAndy |
Jul 24 2023, 11:08 AM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I had a bad crimp connection on one of the big red wires right at the battery terminal.
Looked OK visually but fell apart in my hands after some tugging. A resistance check while wiggling the wires should tell you if you have a bad crimp at either end. (IMG:style_emoticons/default/idea.gif) |
930cabman |
Jul 24 2023, 01:22 PM
Advanced Member Group: Members Posts: 3,128 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
A loose chassis ground connection? Maybe but fell off so wire connector jiggles on the post? That’s what happened at my trans ground a few weeks ago. (IMG:style_emoticons/default/agree.gif) |
ejm |
Jul 24 2023, 02:01 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
You swapped out the regulator and the problem went away. Does it come back if you put the original regulator back in? Since the regulator (and alt harness) both make 3 connections when you plug them in there is no "feel" if each of the connectors are tight. Check the relay board terminals using a single male connector to see if they're making a good connection with the regulator.
VaccaRabite |
Jul 24 2023, 02:57 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Feel under the engine relay baord to make sure you have not pushed one of the spades through the potting so its getting an intermittent connection. Been there.
Also, grounds as previously stated. Zach |
VaccaRabite |
Jul 24 2023, 02:59 PM
Superhawk996 |
Jul 25 2023, 08:34 AM
914 Guru Group: Members Posts: 5,875 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
HF battery load testers are dirt cheap and are an easy way to test the battery to verify it supports load. This will help rule out battery as a potential problem.
Beyond that it sounds a lot like a failing alternator given the fact that you have tried two voltage regulators and that your light is illuminating at 3k rpm (verifies bulb is working). Similarly when you add the large load of headlamps, it seems you’re not able to support that load without dropping voltage. You can full field the alternator to verify output. However if alternator is fluctuating intermittently you probably won’t gain any info unless you can full field it when voltage has already dropped. Check B+ terminal at the alternator and make sure you have a solid connection. Loose terminal or poor connection will lead to flaky behaviour as SirAndy noted. Likewise, if you painted or powder coated the fan shroud make sure you have metal to metal contact between alternator bracket and fan shroud as well as clean connection between fan shroud and engine case. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:05 AM |
