clutch cables for 6 cyl |
rgalla9146 |
Aug 26 2023, 01:01 PM
Advanced Member Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Has anyone purchased a 914 6 clutch cable recently ?
The original part number was 914 423 401 02 and the cable was 3.5 mm My older Gemos still in original packaging with the '6' part number are 3,0mm (IMG:style_emoticons/default/dry.gif) (the 4 cyl. was 914 423 401 05 and the wire was 3.0mm) There is a recent number 914 043 401 08...anyone have experience with it ? Fingers crossed. PS Not interested in terry cables Attached thumbnail(s) |
DennisV |
Aug 26 2023, 03:15 PM
Member Group: Members Posts: 497 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Has anyone purchased a 914 6 clutch cable recently ? I recently purchased 914-423-401-08 Gemo manufactured from Pelican. The length looked good to me, but I did not think to check the diameter. I may be back with the car in a week and can take a measurement. |
mskala |
Aug 26 2023, 06:36 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
A couple weeks ago I bought what was advertised as NOS GEMO and had the part
number on a tag with it. I haven't installed it yet so it was easy to measure, and it's 3.0 mm. |
rgalla9146 |
Aug 27 2023, 05:54 AM
A couple weeks ago I bought what was advertised as NOS GEMO and had the part number on a tag with it. I haven't installed it yet so it was easy to measure, and it's 3.0 mm. Hey Mark, that sounds like the two Gemo 914 423 104 02s I've have for many years. Porsche offers 914 423 401 08 for ~$150. ! Lets see what arrives. |
914Sixer |
Aug 27 2023, 06:15 AM
914 Guru Group: Members Posts: 8,909 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Just curious why would a -6 cable be different than a -4? Same everything as far as mounting and length. I can understand that it might be larger 3.5mm just because things were made more heavy duty, the transmission mounts are a good example.
rgalla9146 |
Aug 27 2023, 08:58 AM
Just curious why would a -6 cable be different than a -4? Same everything as far as mounting and length. I can understand that it might be larger 3.5mm just because things were made more heavy duty, the transmission mounts are a good example. I agree Mark Not only length and mounting but also clutch disc size and (I think) pressure plate strength. Porsche clearly had different part numbers and diffrent spec from the beginning. Plus...I want the right part ! (IMG:style_emoticons/default/smile.gif) |
mb911 |
Aug 27 2023, 10:18 AM
914 Guru Group: Members Posts: 6,897 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Just curious why would a -6 cable be different than a -4? Same everything as far as mounting and length. I can understand that it might be larger 3.5mm just because things were made more heavy duty, the transmission mounts are a good example. I agree Mark Not only length and mounting but also clutch disc size and (I think) pressure plate strength. Porsche clearly had different part numbers and diffrent spec from the beginning. Plus...I want the right part ! (IMG:style_emoticons/default/smile.gif) Clutch disc size? Not diameter but maybe possibly thickness |
914Sixer |
Aug 27 2023, 10:36 AM
Clutch pressure plate are the same. Original -6 disc was the same size, only 6 springs, the -4 was only 4 springs. Now only 6 spring disc are available.
DennisV |
Sep 2 2023, 09:02 AM
recently purchased 914-423-401-08 Gemo manufactured from Pelican measures 2.8mm.
PlaysWithCars |
Apr 22 2024, 11:48 AM
Senior Member Group: Members Posts: 527 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Resurrecting an older post. Was anyone able to conclude the differences between -05 (914-4) and -08 (914-6) part numbers? Need to order a replacement, and I'm perplexed why there isn't one common cable for both. Doesn't seem To be a reason for a difference given that the installations are identical and the pressure plates are the same.
914Sixer |
Apr 22 2024, 05:53 PM
Hard to say. Probably going to be hit or miss. The specifications probably have changed, not knowing what the originals were. Try for old NOS one if available.
Lo-Fi Version | Time is now: 15th June 2024 - 11:39 AM |
