What is the 2 Port fuel pump for replacement of a 3 port pump. |
bdstone914 |
Aug 28 2023, 07:44 PM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Got the one Pelican Parts catalogs for a 75 914 but the big port is 12mm.
It needs an 8 and 9mm port to match the lines on a 74 914. I think Clay listed an Airtex part number? @clayperrine Attached thumbnail(s) |
r_towle |
Aug 28 2023, 10:03 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
5/16 line from tank to pump.
Pump to filter line diameter is based upon the filter Filter to tunnel line is based upon filter and tunnel line Line from tunnel back to tank is 5/16 So, you can use the filter to change diamter |
ClayPerrine |
Aug 29 2023, 04:14 AM
Life's been good to me so far..... Group: Admin Posts: 15,505 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I use an Airtex E-8445. Same pressure and volume specs as a stock 2 port pump. 5.16 in and out. Available from FLAPS.
I have one on Betty's 914, and on the big six. It works great in both applications. And I keep one in the trailer box with a long set of wires and some hose. If we are somewhere on a trip, and the SUV is running really low on fuel, we can transfer the fuel out of the 914 on the trailer into the SUV. It gives us a 16 gallon emergency reserve so we don't get stranded in the middle of nowhere. And if the pump breaks on the 914, we have a spare. |
914Sixer |
Aug 29 2023, 05:29 AM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Bruce,
I have 2 nos 3 ports but the bottom port is the larger version Attached thumbnail(s) |
Lo-Fi Version | Time is now: 4th June 2024 - 12:45 PM |
