| slapshot |
Aug 31 2023, 12:45 PM
Member ![]() ![]() Group: Members Posts: 146 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains
Yesterday just before getting home I heard a click from the engine then again. It wasn't steady, just every little bit I would hear it. I could feel that I lost power and it even stalled once at a stop light. Since I was only a couple block from home I just keep going.
I found that cylinder 3 could only produce 20 lbs of compression. A leak down test was 22% with most air coming out of the intake. For reference the other cylinders were 100 to 105 compression and the leak down was 18% to 20% with air noticed just in the oil filler hole. I don't know how accurate my testing tools are since they are cheap ones I got from amazon and harbor freight. I took off of my valve cover for cylinders 3 and 4 and with cylinder 3 at TDC I have over 1/2 inch of play with both valves and the pushrods are of course way loose. I haven't removed the rockers to pull the pushrods out yet to see if they are bent. I will do that after I pulling the engine either tomorrow or this weekend. How screwed am I? Thoughts on best and worse case? Here's a video of my loose rocker Video of rockers |
| r_towle |
Aug 31 2023, 01:42 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
you may have dropped a valve seat which will wedge against the head and hold the valve down open.
Rich |
| slapshot |
Aug 31 2023, 02:20 PM
I will check for that. That doesn't sound too bad unless the piston hit the valve and bent it.
| 914sgofast2 |
Aug 31 2023, 02:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 796 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Unfortunately, it's probably best to start saving $$$$ for a pair of new cylinder heads and potentially a set of new P&C's. A dropped valve seat or broken valve will likely ruin the piston on #3.
| DRPHIL914 |
Aug 31 2023, 02:43 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I will check for that. That doesn't sound too bad unless the piston hit the valve and bent it. Unfortunately, it's probably best to start saving $$$$ for a pair of new cylinder heads and potentially a set of new P&C's. A dropped valve seat or broken valve will likely ruin the piston on #3. i agree its likely dropped valve seat,that #3 is the most common cylinder, it happened to me 2 years ago, and they dont always cause damage, mind didnt and i had my OEM heads sent out and rebuild with all new stuff, including upgraded new valve seats, new valves, guides springs etc. BUT you might be better off getting new head castings and ahve the same done to them. see what you have once you drop the motor . you can scope it , pull the plug and get an idea if thats the case but, you might as well drop the motor . Phil |
| slapshot |
Aug 31 2023, 03:18 PM
914sgofast2, what is P&C's? Pistons and cylinders?
DRPHIL914, Who did you send your heads to? Was it less than buying new heads? I order a scope last night. I might pull the heads off before it gets here though. The motor's coming out tomorrow. Who makes a good quality head that's reasonably priced? If I do one side, do I need to do the other as well? |
| brant |
Aug 31 2023, 05:25 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
| DRPHIL914 |
Sep 1 2023, 06:33 AM
914sgofast2, what is P&C's? Pistons and cylinders? DRPHIL914, Who did you send your heads to? Was it less than buying new heads? I order a scope last night. I might pull the heads off before it gets here though. The motor's coming out tomorrow. Who makes a good quality head that's reasonably priced? If I do one side, do I need to do the other as well? @slapshot i had a guy in Oregon that is a porsche and VW motor builder for many years do the heads, they can inspect them and make sure they are worth it but i would lean toward just getting new ones, due the heat fatigue to the metal , warping, cracking etc. i can PM you James's info, Ims sure also in Oregon Ben from Martin Mid-engine that used to work with Cary can both get you new heads and build them too. Regarding the source of heads, the castings are new and come from AA i believe but you want bare castings with no hardware, so they then can be built up with quality parts. Places like Stoddards, Sierra Madre etc can get those heads to but they sell them already built but not with the best parts. Phil - PS oh, i think its going to cost about $2500-$3500 for that depeding on the builder and how the heads ar spec'd. bare heads probably under $1,000 Phil |
| rhodyguy |
Sep 1 2023, 08:30 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
End result, to me, is a complete rebuild and EVERY thing else that gets done while you’re in there. Starting with any case work. It gets expensive. Quickly.
| brant |
Sep 1 2023, 08:34 AM
Who built the failing heads?
There just are not many skilled air cooled heads guys left |
| slapshot |
Sep 1 2023, 03:12 PM
Thanks for all the information.
I've only had the car 10 months so I don't have all the info on the engine. The did give me the receipts for maintenance they had. The heads were redone in 2011 by Foreign Auto parts & Service in ST George, UT. What I've found today after removing the engine and the tin around the head, the one of the rocker bolts appears to have blown out. A look through the spark plug hole shows nothing shinny but I'll see more when my scope comes. The valve pushrods are fine. I've got to research how this happened and if it can be repaired. Attached thumbnail(s) |
| ndfrigi |
Sep 1 2023, 04:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
Hoping that is the only issue and can be fix and able to drive the car again.
Probably over tighten that made it broke. |
| 914sgofast2 |
Sep 1 2023, 08:43 PM
Looks like the engine was “rebuilt” by GEX. Go over to the Samba.com website and check out the Bay Window Forum by searching for GEX engines. GEX is the most reviled engine “rebuilder” on planet Earth. ☠️☠️☠️☠️ is the GEX kiss of death. Start saving money now because this episode is likely the first of many to come.
| slapshot |
Sep 1 2023, 11:40 PM
Hoping that is the only issue and can be fix and able to drive the car again. Probably over tighten that made it broke. Thanks for the positive outlook. (IMG:style_emoticons/default/beerchug.gif) |
| slapshot |
Sep 1 2023, 11:47 PM
I retapped the bolt, put the rocker back on and set the gaps. Going to put it back in the car tomorrow. As long as the bolt holds, everything should be back to normal. I'd say that the reason I had no compression on that cylinder was due to the valve not getting pushed open and since the leak down test was descent the valve seat should be okay.
| porschetub |
Sep 2 2023, 01:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,065 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I retapped the bolt, put the rocker back on and set the gaps. Going to put it back in the car tomorrow. As long as the bolt holds, everything should be back to normal. I'd say that the reason I had no compression on that cylinder was due to the valve not getting pushed open and since the leak down test was descent the valve seat should be okay. Did the retapped stud hold the correct torque ? ,looks like the other one has been helicoiled or some other insert. Good luck with this ,sorry to say but you are going to need it,cheers. |
| slapshot |
Sep 2 2023, 07:05 PM
I torqued them to 10ft/lbs. I put the engine back in today check compression and leak down before I started it. Compress was 95 and leak down was 22%. I started it up and it idle great and revving the engines was as well. It didn't seem to have its normal power while driving. I wasn't pushing it at all but could still tell something is still off. It seemed like it was running rich and missing a bit. After I got back I rechecked compression and leak down on all cylinders while still hot. Compression was, starting on cylinder 1: 102, 105, 100, 105. Leak down was 14, 18, 21, 16. That's normal for my engine since I got it. From that I think the engine is fine. Am I missing something?
Next steps is rechecking the timing which I've set not too long ago. I have a 009 distributor with a comp-u-fire module and dual DCNF Webers. Setting time is something I'm not comfortable with. It just doesn't seem to work the same as what I read in the manual. It leaves me scratching my head. After that I'll go through the carbs again. It did seem to run rich on the test drive. It has never felt like that before. I had just got the car running good when the rocker blew. To get it to run good I had to step up to a 65 idle jet which is way big I know. It had 57.5 but backfired at idle and at 2500 RPMs. The car has had a high heating issue since I bought which I haven't solved. Maybe that rocker was screwing with my mixture enough to think I had to increase my idle fuel. |
| porschetub |
Sep 4 2023, 02:20 PM
I torqued them to 10ft/lbs. I put the engine back in today check compression and leak down before I started it. Compress was 95 and leak down was 22%. I started it up and it idle great and revving the engines was as well. It didn't seem to have its normal power while driving. I wasn't pushing it at all but could still tell something is still off. It seemed like it was running rich and missing a bit. After I got back I rechecked compression and leak down on all cylinders while still hot. Compression was, starting on cylinder 1: 102, 105, 100, 105. Leak down was 14, 18, 21, 16. That's normal for my engine since I got it. From that I think the engine is fine. Am I missing something? Next steps is rechecking the timing which I've set not too long ago. I have a 009 distributor with a comp-u-fire module and dual DCNF Webers. Setting time is something I'm not comfortable with. It just doesn't seem to work the same as what I read in the manual. It leaves me scratching my head. After that I'll go through the carbs again. It did seem to run rich on the test drive. It has never felt like that before. I had just got the car running good when the rocker blew. To get it to run good I had to step up to a 65 idle jet which is way big I know. It had 57.5 but backfired at idle and at 2500 RPMs. The car has had a high heating issue since I bought which I haven't solved. Maybe that rocker was screwing with my mixture enough to think I had to increase my idle fuel. Excellant result if they held 10 ft/lbs you should be fine ,I ran 36DCNV's which were the last series made in the 80's so the most modern type of these,great carbs ,I don't remember the exact size of the idle jets but #52 rings a bell you may find yours are too big causing the back fires especially if you have poor response from the mixture screws . I built some custom inlet manifolds and made up a linkage out of T4 carb parts ,bolted up and balanced they were a breeze to tune ,I never changed any jets but did fully rebuild them. Cheers. |
| slapshot |
Sep 5 2023, 09:32 PM
52 sounds about right. My reading indicates that I should be running 50s at my altitude (~4300ft). Mine had 57.5s when I bought it and it backfired at idle and at 2500 RPMs. I went down to 50s and it was a bit worse. The idle mixture screws were turned out 10 & 11 turns on all cylinders. I was shocked at that since you're suppose to start at 2 turns out and work your way back in. That hasn't worked on mine. Mine barely runs at 2 turns out. Even with the 65s I'm at 5 turns out on each. I haven't gone further with these jets since I think the less turns out the better. I've checked the points on each screw and they are all very pointed. Maybe this Weber model is different that the others in the way its tuned. I've got 40 DNCF 101-250 4D. They were put on in 88 by the pervious owner.
Anyway back to my original issue.... I found my loss of power after rethreading the intake side of that rocker was the exhaust side blew out. The exhaust valve was not opening and all that heat was going back into the carb i guess. I did notice the carb was unusually hot after my test drive. I didn't think much about it at the time since I hadn't checked the carb temps after other rides to compare it to. I'm probably lucky it didn't start on fire. I dropped the motor again yesterday and retreaded the exhaust side and put it back in the car. Today I started it up and let it idle for about 15 mins then took the valve cover off and checked the gaps. Looked good so I took it out for a 20 minute easy ride. Power was good and it ran great. Tomorrow I will give it a harder test then check the valve gaps again. |
| ndfrigi |
Sep 5 2023, 10:19 PM
Congratulations! thanks for the update too!
Lo-Fi Version | Time is now: 2nd April 2026 - 02:54 PM |
