Help me ! Help me !, Will my trans fall off |
913B |
Sep 1 2023, 07:34 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Installing my engine/trans after adding my new FI bits and other misc to do in the engine bay.
I cannot seem to get the trans to sit better on the mounts. Check out the pictures and let me know if I need to crawl back under and try do a better job. I did snug down the outer engine mounts first and proceeded to work on the trans mount. I cannot seem to get a good fit. Was that like that before I don't remember. Should I elongate the 2 holes for the trans mount or should I loosen ALL the mounts and see if that might get a better fit. Let me know if you have some observations, tips and recommendations. Thanks a bunch ! Ted (IMG:style_emoticons/default/beerchug.gif) |
SirAndy |
Sep 1 2023, 07:47 PM
Resident German Group: Admin Posts: 41,662 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
That does not look right ...
(IMG:style_emoticons/default/popcorn[1].gif) What does the front of the engine look like? Is the engine tin a tight fit with the seal(s) all around? Did you have the engine and trans separated? Is your engine mount bar bent? (IMG:style_emoticons/default/idea.gif) |
ChrisFoley |
Sep 2 2023, 05:29 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Loosen the outer engine mount bolts and push the bar forward. Then adjust the rear mounts. The trans mounts are safe as is, and should be fine with just a little more engagement on the passenger side.
914Sixer |
Sep 2 2023, 05:50 AM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check to see if motor bar bolts are bent and or the steel mount is tweeked.
913B |
Sep 2 2023, 12:39 PM
The engine was not separated from the trans.
The engine bar is not tweeked looking at all. The long bolts that go through the engine bar, went in easily, so it not bent either. The steel cross bar (3-4 inch) is not obvious looking bent. The front engine tin to rubber seal gap is bit wide, but note I did replace that seal while I had the engine out. I agree that may indicate that my engine is not far forward enough. I will try what Chris Foley suggested. Thanks all, (IMG:style_emoticons/default/beerchug.gif) |
914werke |
Sep 2 2023, 01:03 PM
"I got blisters on me fingers" Group: Members Posts: 10,104 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Are the sport mounts slotted? They dont align perfectly
Lo-Fi Version | Time is now: 29th May 2024 - 02:31 AM |
