> Fuse Panel, Assumptions
Petepat
post Sep 3 2023, 06:36 AM
I've always assumed the feeds to the fuse panel came in on one side and then fed out via the fuse to the other side, but it's not looking like that on my 914. Anybody confirm my experience?
Replies(1 - 2)
davep
post Sep 3 2023, 07:43 AM
914 Historian
In general the feeds come in on one side, and outputs through the fuses. However there are a few circuits that are not fused. For example, Fuses 1 & 2 are for the high beam circuit and are fed from the dimmer relay with fused outputs to each headlight. But there are two white/blue tracer wires that go to the high beam indicator and the fog light relay coming off of the hot side. I had a high beam indicator wire burn out one night because the wire was not fused. So I move these two wires to the fused side of the panel. There are others that are similar.
Petepat
post Sep 5 2023, 05:19 AM
Thanks for that, that was really helpful. Cheers.
- Lo-Fi Version Time is now: 9th July 2025 - 12:04 PM
