| LV2GOFAST |
Sep 4 2023, 12:33 PM
Newbie ![]() Group: Members Posts: 3 Joined: 28-February 14 From: Santa Clarita, CA Member No.: 17,050 Region Association: None |
I rebuilt my 1975 914 1.8 front suspension including the wheel bearings. The ride hight was good and I proceeded to the test drive. After going over a speed bump I started hearing noises from the suspension. upon inspection with the wheels off I noticed the torsion bar adjustment cap had rotated counterclockwise, the adjuster screw no longer touched the stop and I was able to wobble the torsion bar/cap assemble on both sides.
Help please, what did I do incorrectly. There was no rust when disassembled!
Torsion_Bar.MOV ( 524.08k )
Number of downloads: 98 |
| 914Sixer |
Sep 4 2023, 12:44 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,432 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Levers have to be clocked when installing. Read up on how to do.
| jim_hoyland |
Sep 4 2023, 01:04 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,033 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
? What made them come loose ?
| iankarr |
Sep 4 2023, 01:39 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,593 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
My guess is that the splines weren’t firmly seated
| Superhawk996 |
Sep 4 2023, 02:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,733 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
If LCA bushings were replaced, I’ll bet LCA bushings slipped during the test drive - changing the preload on the torsion bar. Known issue with some brands of front LCA bushings.
Reset torsion bar end caps and they won’t likely move that much again now they the initial slip has occurred (assuming bushings were replaced). |
| brant |
Sep 4 2023, 02:29 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,158 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Lo-Fi Version | Time is now: 11th March 2026 - 09:00 PM |
