100W headlight bulbs |
ahklein |
Oct 1 2023, 03:30 PM
Newbie Group: Members Posts: 5 Joined: 22-September 23 From: West Bloomfield, MI Member No.: 27,601 Region Association: Upper MidWest |
I am looking to upgrade the lights on my 1976 914. I have found H4 units with replaceable bulbs. I can buy 100W bulbs for off road use only. Can they be used safely without using an additional relay?
thank so much! |
Geezer914 |
Oct 1 2023, 04:39 PM
Geezer914 Group: Members Posts: 1,434 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I installed them with relays to avoid possibly melting wires. I later swapped the headlights for LED's With the 100w bulbs you can watch the volt meter drop.
Cairo94507 |
Oct 1 2023, 04:44 PM
Michael Group: Members Posts: 9,811 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Please do not put 100W bulbs in your car; our wiring is old and it will not do well. Instead, consider a set of these LED headlights:
https://vintagecarleds.com/shop/7-inch/vc50...ate-7-inch-kit/ I have them in my car. They are plug and play and very bright with no issues for oncoming traffic. I have never been flashed by oncoming traffic. (IMG:style_emoticons/default/beerchug.gif) |
brant |
Oct 1 2023, 04:59 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
They are always installed with relays
Helps if your batter is in the front I ran them for 15 years but went to led Much friendlier on the alt and night driving without worrying |
914Sixer |
Oct 1 2023, 05:21 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
H4 are past history, LED best compromise.
ahklein |
Oct 1 2023, 05:32 PM
Thank you all! Glad I checked
burton73 |
Oct 1 2023, 08:20 PM
burton73 Group: Members Posts: 3,539 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
H4 are past history, LED best compromise. LEDs are more better man. (IMG:style_emoticons/default/smilie_pokal.gif) Bob B |
Mikey914 |
Oct 1 2023, 08:47 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Got most of your next questions right here
https://914rubber-tk.com/doku.php?id=led_he...troubleshooting Entire kit here https://914rubber.com/h4-lens-and-led-bundle-1 Attached thumbnail(s) |
914sgofast2 |
Oct 1 2023, 09:03 PM
Senior Member Group: Members Posts: 622 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
100W bulbs should not be used without a relay. Ask me how I know. Using them without a relay will result in Lucas, the Prince of Darkness, visiting your cars wiring and fuse box to teach you a lesson in the mystery of electricity.
Chris914n6 |
Oct 2 2023, 12:54 AM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I had 80/100w bulbs back in the day. You need to run a dedicated 8 ga wire and relays. The stock system can barely handle stock watts.
I moved up to HID bulbs, but it needs to be in an e-code (euro) h4 housing. The DOT housings glare too much. This was way before LEDs got good. Today I'd buy LED bulbs as they are about the same price as a good HID kit. |
Mikey914 |
Oct 2 2023, 08:58 AM
I used to run aircraft landing lights in the fogs. I often drove the long dark roads of central Washington up to Wenatchee. Found that the truck drivers wouldn't tun off their brights. Making it almost impossible to see. I little click on and they dimmed theirs.
But they did an excellent job of lighting up the road. Yes, I used a relay. |
VaccaRabite |
Oct 2 2023, 09:56 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I used to run aircraft landing lights in the fogs. I often drove the long dark roads of central Washington up to Wenatchee. Found that the truck drivers wouldn't tun off their brights. Making it almost impossible to see. I little click on and they dimmed theirs. But they did an excellent job of lighting up the road. Yes, I used a relay. Back when I had my Mk3 Golf, folks on Vortex would put ACLs in the stock fog light location and quickly melt the plastic "lens" that VW put on there. We would all giggle at how stupid bright they were. I certainly did not know about relays at the time, and folks who did this were dumb kids like me. Wires got melted if they were left on too long. That also made us giggle - so long as it was not our cars. Zach |
Mikey914 |
Oct 3 2023, 10:33 AM
I was a dumb kid, just know about relays as my dad was an electrical engineer. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 3rd June 2024 - 04:50 AM |
