How much Butyl Tape is needed ? |
Literati914 |
Oct 24 2023, 02:48 PM
Senior Member Group: Members Posts: 1,475 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I've seen 45' of butyl tape recommended to do a windshield and rear glass - which seems excessive to me. Will less not get it done? How much is actually needed?
930cabman |
Oct 24 2023, 05:36 PM
Advanced Member Group: Members Posts: 3,144 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
What is the perimeter?
probably not 45' |
hndyhrr |
Oct 24 2023, 05:46 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
at 914rubber
https://914rubber.com/window-butyl front takes two rolls @ 15 feet each, back is one roll @ 15 ft. I did my back window and did not use all of it. |
rhodyguy |
Oct 24 2023, 07:05 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Sooner 5’ long than 6” short.
Literati914 |
Oct 24 2023, 09:03 PM
I've seen 45' of butyl tape recommended to do a windshield and rear glass - at 914rubber front takes two rolls @ 15 feet each, back is one roll @ 15 ft. I did my back window and did not use all of it. Yeah I saw that, I was thinking that their description ^ probably meant that you’d need to buy 2 if ONLY doing the windshield & 1 if only doing the rear glass, ‘cause 45ft sounds like a hell of a lot extra to me. I’ll measure and figure it out, thanks. . |
Bullethead |
Oct 24 2023, 09:05 PM
Oil Cooled heart Group: Members Posts: 897 Joined: 24-June 10 From: South Florida Member No.: 11,875 Region Association: South East States |
Literati914 |
Oct 24 2023, 09:24 PM
Yea, that’s obvious tbh. But can someone confirm that they bought and needed three 15ft rolls to do both? Makes since that one for the rear and one for the front (w/ left over from the rear, if needed) would work. 914rubber would know of course, but I’m suggesting that the wording of the description may be (UN)intentionally misleading. Hopefully someone will confirm one way or the other and/or I’ll just measure the openings. |
Literati914 |
Oct 25 2023, 01:01 PM
So I measured the windshield opening and got a little over 12ft
Attached image(s) |
Literati914 |
Oct 25 2023, 01:02 PM
Then I measured the rubber substitute windshield seal specific to the 914, that I have on hand. Got a little over 13ft.
Attached image(s) |
Shredhead |
Jan 26 2024, 01:18 PM
Member Group: Members Posts: 110 Joined: 10-August 15 From: CT Member No.: 19,047 Region Association: North East States |
Literati914 |
Jan 26 2024, 01:29 PM
Then I measured the rubber substitute windshield seal specific to the 914, that I have on hand. Got a little over 13ft. So why does 914Rubber say you need two for the windshield? I guessing it's unintentional - and should actually sayi you'll need two to do a front AND back set... ie, 2 needed per car (but they leave out the "IF you're doing rear window at the same time" part) . |
Shredhead |
Jan 26 2024, 05:16 PM
Then I measured the rubber substitute windshield seal specific to the 914, that I have on hand. Got a little over 13ft. So why does 914Rubber say you need two for the windshield? I guessing it's unintentional - and should actually sayi you'll need two to do a front AND back set... ie, 2 needed per car (but they leave out the "IF you're doing rear window at the same time" part) . Actually they say two for the windshield and one for the rear window. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:55 AM |
