brer |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None ![]() |
So last night we were working on rotational motion and all i could think about was the crank in my motor and my car going around a corner..
anyone want to help explain this to me? An object spinning at a constant speed has less acceleration at each consecutive point as you move further out from the center. acceleration being related to the radius of the rotational orbit and the constant change in directional velocity. Makes me car sick just thinking about it. (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) |
qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
brer |
(IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
i'm in way over my head. see if i can swim to the surface. |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
so what part of that is not clear to you? you explained it perfectly. look at it this way: picture a big turntable - like a record player (what are those?) or a playground carousel. put an accelerometer 1' away from the center. it will show an acceleration vector toward the rotational center. because its angular velocity is large, it will show a large acceleration. move the accelerometer out 30'. the acceleration vector still points in, but the angular change is smaller, and will show a smaller acceleration. at infinity, the outer edge of the spinning disk is going in a straight line :-) |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Acceleration isn't just a change in speed, it's a change in VELOCITY, which is NOT the same thing. Velocity includes direction as well as speed. Any point on a spinning object is undergoing a constant change in velocity, as it's not going straight, but turning. The acceleration is along the radius of the turn. This is why you feel yourself getting pulled outwards when turning, and it is this force that the tires are resisting.
For a given speed, a larger radius of turning gives a lower change in velocity, and thus a lower acceleration. Going straight is the same as turning on an infinite radius, so zero change in velocity. Spinning an object faster is the same as increasing your speed around the same corner. |
brer |
that was from my notes.
He's about 5 seconds away from erasing the board at any given moment. Holds the eraser in one hand, the pen in the other. |
brer |
which is why doing 60 through a 20mph turn is different than a 40mph turn. Tighter radius at the same speed.
See, i knew this was 914 related! |
Howard |
Incontin(g)ent Member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None ![]() ![]() ![]() |
Are we talking about the same thing? (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
Tom Perso |
Crazy from the Cold... ![]() ![]() ![]() Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 ![]() |
Sounds like someone is in a Dynamics class.... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
I forgot that as soon as I passed... (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Tom |
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
Acceleration is a change in velocity, and velocity includes direction.. (think vectors here) so if you're going 60 mph north, and decide to turn right to be heading east while maintaining the same speed (speed is independent of direction), your northward velocity goes from 60 to zero, and your eastward velocity goes from zero to 60. The tighter the turn, the faster that change happens, and the greater the acceleration, as acceleration is change in velocity over time.
The "centrifugal" force you feel in a turn is a result of your body trying to continue in the same direction at the same speed, due to intertia. |
bondo |
I'm confused by the spinning object situation...
If something is spinning at x RPM, every point on it is changing direction at the same rate. The points farther from the center are moving at a faster speed, but their direction is changing at the same rate as points close to the center. It seems to me that the outside points should have GREATER acceleration if you're looking at constant RPM. This also makes sense in a real world sense as it's trickier to make large hign rpm rotational devices than small ones. Gyroscopes also put most of the mass on the outside. Hmm.. |
phantom914 |
non-914-owner non-club member ![]() ![]() ![]() Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 ![]() ![]() |
You are correct. Acceleration is (V^2)/r (sorry about the poor notation). V = velocity, r = radius. A point twice as far from the center as another point would have twice the velocity and twice the radius. So you would have twice the acceleration for the point further out in this example. A point three times further out would have three times the acceleration etc..... Where did the :Nerd Alert: smilie go? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Andrew |
Sammy |
. ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 ![]() |
as soon as i started reading the other replies it clicked what he was talking about so I deleted my post. Who knew that the stuff I tried so hard to forget 25 years ago would be 914 related?
Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
The spinning object thing is a perfect analogy. Your ice skating and initiate a spin, with your legs and arms swinging out as far as you can stretch. Rotating at 20 RPM. Then take those "objects" (arms and legs) farthest from the center and bring them in closer to your axis..... Huge acceleration. 60 RPM. Why did it do that? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
bondo |
Exactly.. but that's the opposite of the original statement:
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,244 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
think about it this way: the harder you think about it, the *closer* you get to the "center" of this problem, the more it makes your head spin ... voila! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Andy |
brer |
the outlying mass of arms and legs have greater velocity, covering more distance per revolution.
pulling them inward transfers the velocity of those objects to a smaller radius, decreasing the amount of time for one rotation........ in other words, keep your limbs inside the car and maybe i can corner faster. |
Rotary'14 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 ![]() |
what if "D", "O", "G", spelled cat?
Whoa,, now that's some deep sh**! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
tdgray |
Thank God Nemo is not here to see this ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,706 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None ![]() |
OMG... Brain cramp... brain cramp (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
I cannot fathom your lofty ideas...I am but a mere accountant... with three degrees. WTF are you people talking about (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
those playground merry-go-rounds spin much too quickly if you sit in the center. if you go to the outer edge, the g-forces can kill you. you travel further, but slower, before you die. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
k |
Lo-Fi Version | Time is now: 4th July 2025 - 12:19 AM |
