> Distributor Cap Wiring Positions for 914-6
DennisV
post Dec 9 2023, 10:34 AM
I looked high and low in the workshop manuals but could not find mention of the distributor cap wiring connections for the 914-6. Is the wiring order and clockwise rotation shown in the photo below correct? I took this from a 911 sticker.
I am creating a quick reference sheet for myself as I prepare to reassemble our engine.
P.S. Believe it or not, not all 911 are the same. I guess the SC turns counter clockwise?
Replies(1 - 6)
fixer34
post Dec 9 2023, 03:42 PM
QUOTE(DennisV @ Dec 9 2023, 10:34 AM) *
That is the correct rotation and firing order on a -6. Once you line up the #1 position on the distributor with the TDC mark on the flywheel, you are good. However, make sure you properly identify the cylinder locations. According to the sticker on mine, #1 is the rear most on the driver side, (as referenced with the engine installed, fan facing forward).
Fan
3 6
2 5
1 4
rgalla9146
post Dec 9 2023, 04:14 PM
The # 1 CYLINDER on a 914 6 is the one closest the passenger seat.
# 2 and #3 are behind #1 in order
#4 is closest the drivers seat and #5 and #6 are behind #4 in order.
Marelli dizzy ?
The spade connector on the dizzy points straight at the seat bulkhead.
The tip of the rotor is over the notch on the rim of the dizzy, the #1 wire
is in the socket over the tip of the rotor.
Your illustration shows the firing order. Place the wires in the cap in that order
starting with # 1
DennisV
post Dec 10 2023, 08:53 AM
QUOTE(fixer34 @ Dec 9 2023, 01:42 PM) *
Thank you.
Interesting that you mention the sticker. Our car too has what appears to be a 911 sticker, if you consider that arrow normally indicates the "direction of travel" in the workshop manuals.
rgalla9146
post Dec 10 2023, 09:35 AM
QUOTE(DennisV @ Dec 10 2023, 09:53 AM) *
Thank you.
Yes. The direction of travel arrow is wrong for a 914 6
# 1 is closest to the passenger seat.
fixer34
post Dec 10 2023, 08:37 PM
QUOTE(rgalla9146 @ Dec 10 2023, 09:35 AM) *
Thank you.
Looking at this again, is the 'wide' portion of the diagram the fan assembly or the flywheel? If the flywheel, then you essentially have to turn the sticker upside down to get the correct physical location perspective.
sixnotfour
post Dec 10 2023, 08:49 PM
flywheel
- Lo-Fi Version Time is now: 12th May 2025 - 06:11 AM
