roundtwo |
Member ![]() ![]() Group: Members Posts: 325 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California ![]() ![]() |
First time taking off the wheels for new tread. The lug nut pictured as B is what’s on the car. Is that the correct lug nut for the wheel or should it be the lug nut pictured as A ? Different shoulders/flang as I’m not sure which is stock for the rims.
Is bolt be the correct length? Seams about right as the hub of the wheel is fairly thick. I forgot to measure the bolts ![]() ![]() |
bzettner |
Member ![]() ![]() Group: Members Posts: 213 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region ![]() |
Almost 100% that my Pedrinis use a 40mm lug bolt (IMG:style_emoticons/default/beer3.gif)
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,186 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Bolt A has the correct flange (ball seat cup) and needs to be 40 mm.
Bolt B is totally incorrect. Here is a more correct option. Factory bolts had 19 mm heads, these are 17mm. Attached thumbnail(s) ![]() |
roundtwo |
NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,378 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
Same for Mahle and Pedrini I am guessing?
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,628 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
BENBRO02 |
Member ![]() ![]() Group: Members Posts: 485 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region ![]() ![]() |
I believe the short ones are for steel wheels because they are not as thick.
Lo-Fi Version | Time is now: 4th July 2025 - 11:42 AM |
