Gatornapper |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,280 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States ![]() ![]() |
Need help with identifying the terminals on the front marker lights, part #91463140111.
My painter re-connected them incorrectly and the circuit is shorted. I've looked everywhere but nowhere can I find which terminal is which. Terminals are "BL", "34" and "57". These are not the numbers on the schematic that I have. One is ground, one is marker lights, one is turn signal. A little help with which is which is appreciated. I can't "ring" them out checking resistance as I have LED's in and don't want to pull everything apart. Lazy I guess. TIA, GN |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,202 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Need help with identifying the terminals on the front marker lights, part #91463140111. My painter re-connected them incorrectly and the circuit is shorted. I've looked everywhere but nowhere can I find which terminal is which. Terminals are "BL", "34" and "57". These are not the numbers on the schematic that I have. One is ground, one is marker lights, one is turn signal. A little help with which is which is appreciated. I can't "ring" them out checking resistance as I have LED's in and don't want to pull everything apart. Lazy I guess. TIA, GN Terminal 31 is ground. You noted 34. Terminal BL is turnsignal Terminal 57 is running light |
Gatornapper |
As always - thanks Spoke!
GN Need help with identifying the terminals on the front marker lights, part #91463140111. My painter re-connected them incorrectly and the circuit is shorted. I've looked everywhere but nowhere can I find which terminal is which. Terminals are "BL", "34" and "57". These are not the numbers on the schematic that I have. One is ground, one is marker lights, one is turn signal. A little help with which is which is appreciated. I can't "ring" them out checking resistance as I have LED's in and don't want to pull everything apart. Lazy I guess. TIA, GN Terminal 31 is ground. You noted 34. Terminal BL is turnsignal Terminal 57 is running light |
Lo-Fi Version | Time is now: 31st July 2025 - 11:00 AM |
