Wilwood big brakes, 914-4 brakes |
Freezin 914 |
Jan 21 2024, 09:22 PM
Senior Member Group: Members Posts: 872 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
I figure some here will have more info on this, but Wilwood is advertising it has a big brake available for 914-4s. Just in case anyone would be interested. I haven’t even looked it up yet, but seen the ad in Excellence.
burton73 |
Jan 21 2024, 10:24 PM
burton73 Group: Members Posts: 3,541 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I figure some here will have more info on this, but Wilwood is advertising it has a big brake available for 914-4s. Just in case anyone would be interested. I haven’t even looked it up yet, but seen the ad in Excellence. You guys must see what size wheels will clear the brake. Will it need a 16 inch or will a 15 work? Best Bob |
Freezin 914 |
Jan 22 2024, 06:42 AM
I did go on their site, really didn’t find much. But here is the ad.
Attached thumbnail(s) |
Geezer914 |
Jan 22 2024, 07:34 AM
Geezer914 Group: Members Posts: 1,439 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
It appears the cost F&R would be around $1800-2000. You have to weigh the benefit vs cost over stock performance for a street car. Maybe on a race set up it would be justified. Stock calipers with Porterfield pads work great.
GregAmy |
Jan 22 2024, 07:46 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
That is quite interesting!
But I'm with John (Geezer). I historics-race a 914-4 and find that the front brakes are quite adequate with the right pads; in fact, if I had a lot more front brake I'd probably be running into bias problems and possibly front lockup. For reference, I'm running the BMW calipers, stock rotors, Hawk Blue pads, manual bias valve typically dialed a lot to the rear, and Hoosier Speedster or Continental Extreme tires. However, one big advantage I see: replaceable rotor rings! It would be wicked cool to be able to do rotor replacments without having to repack/replace bearings. And, of course, they look pimpy cool (I race Wilwood brakes on the SCCA Produciton car and love 'em). I sent them an inquiry for more info. |
mepstein |
Jan 22 2024, 07:47 AM
914-6 GT in waiting Group: Members Posts: 19,312 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Just call them. I forget his name but they know their product.
BIGKAT_83 |
Jan 22 2024, 07:55 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Did mine 20years ago when they were $100 a caliber
Superhawk996 |
Jan 22 2024, 08:17 AM
914 Guru Group: Members Posts: 5,891 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Fact: tire grip is the single largest contributor to stopping distance.
For most people, they would get more out of a better set of tires than they would out of “upgrading” to “big” brakes. |
Shivers |
Jan 22 2024, 08:18 AM
Senior Member Group: Members Posts: 2,417 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Olympic 914 |
Jan 22 2024, 08:23 AM
Group: Members Posts: 1,675 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Freezin 914 |
Jan 22 2024, 08:41 AM
Just wanted to let people know, I know I don’t need the bigger brakes, but I know plenty of you have bigger hp 6’s, Suby’s, do autox etc…..
Shivers |
Jan 22 2024, 08:51 AM
They look smaller than these and I need 16” minimum rims to fit. A big plus is weight. The M calipers that I have for the back weigh a ton, compared to the larger wilwoods for the front. What rotor are you running? 20 mm Vented or 24mm vented. 20mm (IMG:style_emoticons/default/smile.gif) |
brant |
Jan 22 2024, 08:52 AM
914 Wizard Group: Members Posts: 11,635 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Fact: tire grip is the single largest contributor to stopping distance. For most people, they would get more out of a better set of tires than they would out of “upgrading” to “big” brakes. (IMG:style_emoticons/default/agree.gif) |
Shivers |
Jan 22 2024, 08:59 AM
Just wanted to let people know, I know I don’t need the bigger brakes, but I know plenty of you have bigger hp 6’s, Suby’s, do autox etc….. Weigh and horsepower make a difference, but the way you drive it also makes a difference what kind of brakes you might want. Stock worked pretty good for a while. But the braking would become less effective as my drive proceeded. So if you are cruising to cars and coffee in it, the stock brakes with some of those cool pads Eric sells will work great. |
Superhawk996 |
Jan 22 2024, 09:17 AM
06:41 AM'] Just wanted to let people know, I know I don’t need the bigger brakes, but I know plenty of you have bigger hp 6’s, Suby’s, do autox etc….. Weigh and horsepower make a difference, but the way you drive it also makes a difference what kind of brakes you might want. Stock worked pretty good for a while. But the braking would become less effective as my drive proceeded. So if you are cruising to cars and coffee in it, the stock brakes with some of those cool pads Eric sells will work great. (IMG:style_emoticons/default/agree.gif) with the general premise but . . . Horsepower makes no difference at all to single stop, stopping distance. Because . . . Physics. Force = mass * acceleration. There is nothing in that equation affected by horsepower. Note: acceleration in the braking case is simply deceleration. Opposite direction of forward acceleration. Horsepower only comes into play with repeated, hard at limit braking, with short intervals between events that limit cooling between braking events. Track use, canyon carving come to mind. I autocrossed for years on stock brakes with race compound pads and didn’t have fade since average run is only a couple minutes in duration. Note; not a critique of Shivers. Just get tired of the internet mythology that horsepower has any bearing upon single stop, stopping distance. |
GregAmy |
Jan 22 2024, 09:21 AM
Stock worked pretty good for a while. But the braking would become less effective as my drive proceeded. You need different pads, brother. Not speaking to you directly, but it is simply amazing to me how most car guys don't understand how the pad compound you use really makes a substantial difference. Seriously. Many a braking complaint is easily resolved by "the right pad". And many a problem is caused by someone thinking they understand the concepts but getting it wrong ("why are these Hawk Blue pads tearing up my street car's rotors so bad??") Today's pad compounds are fricken amazing. I would have killed decades ago for this technology*. And today we take it for granted... I'd be glad to make suggestions, if we could just discuss what you're doing with them and whose pads you prefer. GA *Try racing Road America or Road Atlanta with dead-stock pads. That's what we used to have to do in the old Showroom Stock days of the 1980s: stock parts only. I'd go through a set of pads literally every session, and another set 3/4 into the race (seems like the braking got better when it went down to metal-to-metal...but it made a lot of noise). Lap One Turn One at the Road Atlanta Runoffs smelled like a brake pad factory... |
Superhawk996 |
Jan 22 2024, 09:37 AM
. . (seems like the braking got better when it went down to metal-to-metal...but it made a lot of noise). Metal to metal is much higher coefficient of friction than pad to metal. Your perception is correct. And pretty stable (not changing friction) much with increasing temperature. The rotor wear on the other hand (IMG:style_emoticons/default/lol-2.gif) |
Superhawk996 |
Jan 22 2024, 09:39 AM
Stock worked pretty good for a while. But the braking would become less effective as my drive proceeded. You need different pads, brother. (IMG:style_emoticons/default/agree.gif) The main problem though is race pads on the street really suck when pads are cold and first few stops are sketchy. Ask me how I know (IMG:style_emoticons/default/laugh.gif) |
Freezin 914 |
Jan 22 2024, 09:56 AM
Stock worked pretty good for a while. But the braking would become less effective as my drive proceeded. You need different pads, brother. (IMG:style_emoticons/default/agree.gif) The main problem though is race pads on the street really suck when pads are cold and first few stops are sketchy. Ask me how I know (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/agree.gif) I have done my fair share of racing in my day…most of the time, race parts are just that, for racing, not street driving, even aggressive street driving. Especially suspension and brakes, tempof the brakes is huge! But also race suspension isn’t really designed for street use. Most roads have bumps, potholes, gravel, etc…stiff race suspension won’t keep the tires in contact with the pavement as a bit softer set up. Either way, I digress, just happy people seen this thread and are at least talking about it. As for me, keeping it stock in the brake department, but may use a bit better pads for when I feel the need… (IMG:style_emoticons/default/happy11.gif) |
Jamie |
Jan 22 2024, 10:15 AM
Senior Member Group: Members Posts: 1,034 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
Stock worked pretty good for a while. But the braking would become less effective as my drive proceeded. You need different pads, brother. (IMG:style_emoticons/default/agree.gif) The main problem though is race pads on the street really suck when pads are cold and first few stops are sketchy. Ask me how I know (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/agree.gif) I have done my fair share of racing in my day…most of the time, race parts are just that, for racing, not street driving, even aggressive street driving. Especially suspension and brakes, tempof the brakes is huge! But also race suspension isn’t really designed for street use. Most roads have bumps, potholes, gravel, etc…stiff race suspension won’t keep the tires in contact with the pavement as a bit softer set up. Either way, I digress, just happy people seen this thread and are at least talking about it. As for me, keeping it stock in the brake department, but may use a bit better pads for when I feel the need… (IMG:style_emoticons/default/happy11.gif) OK gang, for those of us street drivers with mostly stock cars, what brand of pads do you recommend for replacement with stock calipers? (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 03:46 AM |
