> I am tired of crawling around under jack stands to work on my 914, WHat type of scissor lifts are you running
pete-stevers
post Feb 2 2024, 05:22 PM
Shinee Side Up
I dont really have room in the garage for a two post lift.. so I figure a scissor lift might be better... let me know what you think. My ceiling is 11 feet and don't want to spend more than 2000 ish... or am i out to lunch...
Replies(1 - 19)
FlacaProductions
post Feb 2 2024, 05:59 PM
EZ-CarLift and a high speed drill.
https://www.ezcarlift.com
no hyraulic fluid or auxiliary boxes, etc.
Cairo94507
post Feb 2 2024, 06:06 PM
Michael
In my last home I did a mid-rise scissor lift, BendPak, and I loved it. Sunk into garage floor so when it was down, totally flush with the floor- no trip hazard. We ran the hydraulic lines in the floor too. Mounted the mechanicals under a counter in a cabinet and the only thing you saw was a control panel with the controls on the side of a cabinet. Very low-profile, clean install.
If you send me your email address I can send you photos.
Cheers,
Michael (IMG:style_emoticons/default/beerchug.gif)
post Feb 2 2024, 06:12 PM
914-6 GT in waiting
Any decent lift will be a game changer.
tygaboy
post Feb 2 2024, 06:23 PM
I have QuickJacks and love them. I don't like sissor lifts because they block so much of the underside, they are HEAVY and take up a lot of room.
Price aside, have you looked at MaxJacks? Portable 2-post that work with low ceilings.
https://www.maxjax.com/
bandjoey
post Feb 2 2024, 06:49 PM
bandjoey
QUOTE(FlacaProductions @ Feb 2 2024, 05:59 PM) *
Can you do valve adjustments with this lift? Looks like the side bars block that area
JeffBowlsby
post Feb 2 2024, 07:07 PM
How about a used 4-post lift? 11ft clear is sufficient and a 4-post gives you storage space and great access from below.
pete-stevers
post Feb 2 2024, 07:39 PM
Shinee Side Up
How is dropping engines with a scissor lift? or engine access?
BillJ
post Feb 2 2024, 07:57 PM
Love my quickjack.
Freezin 914
post Feb 2 2024, 08:28 PM
In the past have had a scissors lift (titan), and now have a quick Jack. They both have their place, including every other lift listed. Personally, quick jacks are great for a guy like me, weekend warrior, small maintenance projects, if I where doing more serious repairs, restoration, rebuilding,or had multiple cars, I would consider something more robust like a MaxJack, 4 post, or scissors again. Just my .02 as most have said, any lift is better than a floor Jack…
Mitox
post Feb 2 2024, 09:05 PM
I’ve been looking for a lift also, and found this one at Harbor Freight for $2000.
Freezin 914
post Feb 2 2024, 09:08 PM
QUOTE(Mitox @ Feb 2 2024, 09:05 PM) *
Looks like a titan to me. Made in Indiana I believe.
Mitox
post Feb 2 2024, 09:20 PM
QUOTE(Freezin 914 @ Feb 2 2024, 10:08 PM) *
Yeah, most likely every unit like this is made by the same manufacturer.
dhuckabay
I got a two post Chinese lift off ebay. Think it was about 1500 delivered. Installed in a half day. Really well built. My son is a mechanic and uses it a lot. Never had any problems with it. Very good safety devices to keep it from coming down at the wrong time. Did build some wood pads to elevate the low slung cars.
Krieger
post Feb 2 2024, 11:25 PM
QUOTE(bandjoey @ Feb 2 2024, 04:49 PM) *
Yes you can. I have 2 different length crossbars (not the aluminum rails you see). Depending on what I am doing I run the aluminum rails on the sides of the car, or sometimes turned 90°. The EZ lift is 120#s. I stand mine against the wall when I am not using it.
Rufus
post Feb 3 2024, 12:48 AM
QUOTE(JeffBowlsby @ Feb 2 2024, 06:07 PM) *
I bought a used Rotary 4 post. Installation under a 10.5’ ceiling was a pretty straight forward one man job. IIRC required renting a hammer drill for putting holes in garage floor. Other tools like a good (laser’s best) level, plumb bob (I used to check level accuracy), are recommended.
Still in my garage but not set up now, but miss it almost every day. Very useful for storing and / or working on cars.
Having a 914’s a plus due to its low height.
Something to keep in mind when comparing the height stack up of cars and lift (for storage use) to ceiling height, it’s important to subtract the total floor slope from the ceiling height. Builders typically build in a slope for water drainage. If I’d considered this beforehand, I would have insisted on a zero slope floor.
mlindner
post Feb 3 2024, 05:15 AM
Bendpak, I had mine for 15 years. Love it. Easy engine/trans install.Attached Image Attached Image
mlindner
post Feb 3 2024, 05:23 AM
Easy engine install. Plenty of room. Best, MarkAttached Image
BK911
post Feb 3 2024, 06:51 AM
Another vote for harbor freight.
Had mine for 20 years.
Dozens of 911 912 356 914 had brake suspension or engine work done over the years.
One of the best tools I ever bought.
mlindner
post Feb 3 2024, 08:23 AM
Topliftcar, has the Bendpak lift for $1,500 with free shipping.
7 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th November 2026 - 03:24 PM
