Dizzy timing workaround? |
torakki |
Mar 14 2024, 07:32 PM
Newbie Group: Members Posts: 43 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California |
I'm trying to adjust timing on my 2.0L and ran into an issue. The bolt you loosen, to rotate the dizzy, is underneath the vacuum can. I can't seem to find a tool to get under there to loosen or tighten. I've had the dizzy out and removed the vacuum advance and it's no problem getting to it. Is there something way off with my distributor?
Thanks for telling me the secret. |
r_towle |
Mar 14 2024, 07:35 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Post a picture from above.
Close enough to see the whole distributor from above Far enough back to see the nearby fan housing. You may have the vacuum can on backwards, but not sure how you could. The nut to loosen is 13mm, and using a wrench you can reach it. |
Lo-Fi Version | Time is now: 10th June 2024 - 03:33 AM |
