Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,854 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Does anyone know if the dimensions of the dash switch caps in 911s is similar to the ones we have in our 914s (same as Beetle)?
I was wondering if this cap below would fit in our switches. (IMG:style_emoticons/default/idea.gif) ![]() Last question... (IMG:style_emoticons/default/rolleyes.gif) Does anyone know if this cap is used on a back lit switch? Thank you! |
slotty008 |
Member ![]() ![]() Group: Members Posts: 192 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None ![]() ![]() |
Does anyone know if the dimensions of the dash switch caps in 911s is similar to the ones we have in our 914s (same as Beetle)? I was wondering if this cap below would fit in our switches. (IMG:style_emoticons/default/idea.gif) ![]() Last question... (IMG:style_emoticons/default/rolleyes.gif) Does anyone know if this cap is used on a back lit switch? Thank you! I just compared them since at the moment I have them both in my garage. I think the dimensions are the same but I'm not sure of the shape. And I can't get them out of the switch. In the 911 it's a back lit switch.Never used it. |
Montreal914 |
Does anyone know if the dimensions of the dash switch caps in 911s is similar to the ones we have in our 914s (same as Beetle)? I was wondering if this cap below would fit in our switches. (IMG:style_emoticons/default/idea.gif) Last question... (IMG:style_emoticons/default/rolleyes.gif) Does anyone know if this cap is used on a back lit switch? Thank you! I just compared them since at the moment I have them both in my garage. I think the dimensions are the same but I'm not sure of the shape. And I can't get them out of the switch. In the 911 it's a back lit switch.Never used it. Thank you for this information. Is the headlight switch also illuminated? I am considering having heated seats in my car eventually. Ideally the seat switches would be of the era. I find this defrost cap somewhat close to the typical heated seat sign. A two position switch (such as headlight) with backlighting would be super! I would probably install a red LED and figure a way for it to have two intensities with low on the parking lights 1st position for low heat setting, and high intensity in the headlights positions for high heat. All of this could be driven by relays to preserve the switch. Edit: It looks like the 993 headlight switch is backlit. I assume it has two positions... |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,186 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
NO lip on outer edge, nothing to lock into rubber knob
Attached image(s) ![]() |
Montreal914 |
NO lip on outer edge, nothing to lock into rubber knob Not sure I understand what you mean… (IMG:style_emoticons/default/confused24.gif) The 911 don’t have the lip? But my picture is from a 911 defrost. I know the 914 (like the beetle) have a lip… |
slotty008 |
The headlight switch of a 911 3.2 is not backlit but I found out now (after 8 years) that the rear window defroster switch has 2 positions : pull for defogging and turn to the right for defrosting,
so maybe you can use this as your seat switch. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 6th July 2025 - 09:09 PM |
