Front a arm caps |
Front a arm caps |
jmargush |
Apr 19 2024, 01:10 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
dr914@autoatlanta.com |
Apr 19 2024, 01:11 PM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
mepstein |
Apr 19 2024, 01:46 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Press fit. I would put a small dab of epoxy if you want to be sure.
Superhawk996 |
Apr 19 2024, 04:11 PM
914 Guru Group: Members Posts: 5,892 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
They operate like a Welch plug. They have a dome shape. Dome goes to the front with the protrusion facing out.
Then use an appropriate sized socket or punch. Hammer in slightly - this expands the diameter of the plug to a tight fit that wont come loose on its own. I wouldn’t peen or tack weld. The plug is designed such that you can drive the torsion bars out the front and pop out the Welch plug / cap when the torsion bar pushes it out. Then reuse or replace (new plugs are available). |
jmargush |
Apr 20 2024, 03:47 AM
Got it
Thanks |
Lo-Fi Version | Time is now: 8th June 2024 - 12:48 AM |
