FI, fuel in the contact-points on the injectors |
gun22 |
Apr 28 2024, 11:36 AM
Newbie Group: Members Posts: 16 Joined: 25-January 24 From: Norway Member No.: 27,878 Region Association: Scandinavia |
1973 2,0 FI
Planning to renew the fuel system in winter, just cruising this spring/summer in my resent buy I thought. Heavy smell of fuel in engine-bay, located fuel in contactpoint on injectors where the wiring is put, the two rear injectors on each side most disturbing. Car runs very good, spark plugs fine no fire yet..... Any hot tip? Fuel-line fittings looks and feels OK, will take out injectors and inspect inner and outer rubber bushings, but can’t figure out how the fuel take that route.... |
technicalninja |
Apr 28 2024, 11:50 AM
Senior Member Group: Members Posts: 1,330 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Cracked/porose injector plastic.
Dangerous! Verify by completely drying harness recess in the body and merely turning FP on. Get wet again? I'd replace ALL of the injectors. Nissan had a HUGE class action in the early 90s regarding this type of leakage. I'd done 9 complete injector replacements on customer cars by that point. Nissan REPAID all of my customers for my work AND replaced what I installed with brand new stuff. One of the most enjoyable things I've done as a shop owner were those phone calls. "You want your money back?" "If you don't have a copy of the receipt, I do..." They didn't even have to own the car anymore! Got almost 10K back to the customers in total. |
gun22 |
Apr 28 2024, 12:52 PM
Thank you for info and your experience. Get’em out and decide on which type to invest in....
Cracked/porose injector plastic. Dangerous! Verify by completely drying harness recess in the body and merely turning FP on. Get wet again? I'd replace ALL of the injectors. Nissan had a HUGE class action in the early 90s regarding this type of leakage. I'd done 9 complete injector replacements on customer cars by that point. Nissan REPAID all of my customers for my work AND replaced what I installed with brand new stuff. One of the most enjoyable things I've done as a shop owner were those phone calls. "You want your money back?" "If you don't have a copy of the receipt, I do..." They didn't even have to own the car anymore! Got almost 10K back to the customers in total. |
technicalninja |
Apr 28 2024, 01:12 PM
I've only seen that on early Nissan VG30s.
The elbows are far more likely to leak. Make sure you're not seeing leakage from the rubber parts. But, if you diagnose leakage through the plastic I wouldn't trust any of them... |
emerygt350 |
Apr 28 2024, 03:05 PM
Advanced Member Group: Members Posts: 2,144 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
The fj67s are what you want. Cheap. Work well. But make sure it isn't the elbow first.
gun22 |
Apr 29 2024, 03:29 AM
Noted.
Had a look at these ones from Injector rehab when I planned for winter fix, maybe they need to come in the garage sooner... The fj67s are what you want. Cheap. Work well. But make sure it isn't the elbow first. Attached image(s) |
VaccaRabite |
Apr 29 2024, 06:13 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
emerygt350 |
Apr 29 2024, 06:22 AM
I am not sure I like the look but that has got to be far better for the seals. The current design is less than optimal with the elbows and hold downs.
gun22 |
Apr 29 2024, 03:12 PM
Noted. Had a look at these ones from Injector rehab when I planned for winter fix, maybe they need to come in the garage sooner... That is SEXY. If I still used intake runners I would buy a set of those in a heartbeat. So much better! Zach (IMG:style_emoticons/default/biggrin.gif) |
gun22 |
Apr 29 2024, 03:48 PM
Well, the original design has been doing it’s work for a long time I suppose, maybe just renew it close to original standard with fj67, though I can see benefits.
(BTW, Changed injectors and fuel rails this winter on a T3 Wasserboxer Bus, preventive, Gowesty style, a more handy design, lots of space back there offcourse). On an other tread now in april an other liebhaber has done the swap, reffering to it when I find out how to... Take the old ones out tomorrow and then decide! I am not sure I like the look but that has got to be far better for the seals. The current design is less than optimal with the elbows and hold downs. |
GregAmy |
Apr 29 2024, 05:12 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I like that injector setup. But how are they getting the EV14s to seal in the stock manifold? Is it the same size seal?
https://injector-rehab.com/product/complete...ctors-included/ I just put in a new set of EV1-type connectors in my Microsquirt build, wish I'd seen these before... https://www.fiveomotorsport.com/high-impeda...jaguar-porsche/ |
gun22 |
Apr 30 2024, 09:20 AM
Getting wiser evert minute, putting new rubbers on and check for leaks and wet contactpoints after a guick startup.
They all look the same, though I can see some minor differences, the one with the green tip is the one with fuel in the el. contactpoint. I like that injector setup. But how are they getting the EV14s to seal in the stock manifold? Is it the same size seal? https://injector-rehab.com/product/complete...ctors-included/ I just put in a new set of EV1-type connectors in my Microsquirt build, wish I'd seen these before... https://www.fiveomotorsport.com/high-impeda...jaguar-porsche/ Attached thumbnail(s) |
technicalninja |
Apr 30 2024, 09:47 AM
You have 3 different (style/age?) injectors in that...
Someone used worm clamps on the hoses (which look like crap anyways). That alone would "deadline" those for me. I'd hunt some of the FJ67s down OR maybe change up to the new style EV14s. If the EV14s will work with the ECU I'd make sure to get same flow rate as the originals. Every time I've installed EV14s I've ALSO installed an aftermarket digital FI ecu. The EV14s I use have always been 700-1000cc units and REQUIRE adjustable pulse times that you can adjust with a laptop. But, if the impedance and flow rate is the same they should work fine with old technology. |
gun22 |
May 3 2024, 12:04 PM
4 injector FJ67’s from RockAuto on it’s way, arriving Monday!
Sticking to the original outfit, hope that will do it. Thanks all for comments and advice!0 quote name='technicalninja' date='Apr 30 2024, 09:47 AM' post='3142393'] You have 3 different (style/age?) injectors in that... Someone used worm clamps on the hoses (which look like crap anyways). That alone would "deadline" those for me. I'd hunt some of the FJ67s down OR maybe change up to the new style EV14s. If the EV14s will work with the ECU I'd make sure to get same flow rate as the originals. Every time I've installed EV14s I've ALSO installed an aftermarket digital FI ecu. The EV14s I use have always been 700-1000cc units and REQUIRE adjustable pulse times that you can adjust with a laptop. But, if the impedance and flow rate is the same they should work fine with old technology. [/quote] |
gun22 |
May 27 2024, 03:09 AM
New FJ67 injectors fitted, side entrance for the electric connectors, woorking fine now after 60 miles driving, the old one in the middle of pic.
[quote name='gun22' date='May 3 2024, 12:04 PM' post='3142986'] 4 injector FJ67’s from RockAuto on it’s way, arriving Monday! Sticking to the original outfit, hope that will do it. Thanks all for comments and advice!0 quote name='technicalninja' date='Apr 30 2024, 09:47 AM' post='3142393'] You have 3 different (style/age?) injectors in that... Someone used worm clamps on the hoses (which look like crap anyways). That alone would "deadline" those for me. I'd hunt some of the FJ67s down OR maybe change up to the new style EV14s. If the EV14s will work with the ECU I'd make sure to get same flow rate as the originals. Every time I've installed EV14s I've ALSO installed an aftermarket digital FI ecu. The EV14s I use have always been 700-1000cc units and REQUIRE adjustable pulse times that you can adjust with a laptop. But, if the impedance and flow rate is the same they should work fine with old technology. [/quote] [/quote] |
gord |
May 27 2024, 08:03 AM
Member Group: Members Posts: 76 Joined: 30-May 20 From: Toronto, Canada Member No.: 24,334 Region Association: Canada |
I like that injector setup. But how are they getting the EV14s to seal in the stock manifold? Is it the same size seal? https://injector-rehab.com/product/complete...ctors-included/ Not sure how I missed this post a month ago—I installed the Injector Rehab fuel rail in my car earlier this season (see my post here). Regarding the manifold seal, they modify the injectors by replacing the grommet at the nozzle end of the injector with a larger one, as you can see in this photo: |
Lo-Fi Version | Time is now: 8th June 2024 - 12:15 PM |
