brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,946 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
This is the single port throttle body that started in 1974
as posted below.. possibly from a 75/76 model year not completely certain for some reason it is missing the return spring shafter is good, smooth, not dug into the butterfly used... not new. 130 and I'll ship within the US Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,335 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
IIRC, The 74 did not have the big spring. It was in 75\76.
brant |
I couldn’t remember
For sure the 73 did not have the spring Could be 75/76 |
brant |
trying to combine this into one thread as it should have been initially.
this one is an Ljet... used... the shaft is good, moves freely. and a little wear, but not loose, worn out, nor dug into the butterfly. 130 and I'll cover US shipping. Attached image(s) ![]() ![]() ![]() ![]() ![]() |
brant |
I have a box full of throttle bodies.
here is another.... this is a 1.7 style. includes a TPS I opened the cover to show the trace tracks. no open circuits again no loose play in the shaft but does have a little wear still very useable though with TPS 110$ and I'll ship in the US Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
friethmiller |
Senior Member ![]() ![]() ![]() Group: Members Posts: 860 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region ![]() ![]() |
I'm looking for a complete '74 2.0L D-jet throttle body.
brant |
I'm looking for a complete '74 2.0L D-jet throttle body. I've got a complete 73 dual port, no return spring that would functionally work Might have a complete 75 single port too... can double check tonight... but not 100% certain of this... but if the 74 did not have the return spring... then I don't have that one.... although a 75 with return spring should still work... as any of them between 73 - 76 could work/interchange into 1974 with capping one port sorry 74 is the one I may not have from a perfect concourse perspective. brant |
black73 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 517 Joined: 23-March 05 From: Nashville,TN Member No.: 3,801 Region Association: South East States ![]() |
Pm sent for 1.7 TB and TPS.
DC_neun_vierzehn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 509 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region ![]() ![]() |
I'm looking for a complete '74 2.0L D-jet throttle body. I've got a complete 73 dual port, no return spring that would functionally work Might have a complete 75 single port too... can double check tonight... but not 100% certain of this... but if the 74 did not have the return spring... then I don't have that one.... although a 75 with return spring should still work... as any of them between 73 - 76 could work/interchange into 1974 with capping one port sorry 74 is the one I may not have from a perfect concourse perspective. brant @brant I would be interested in the 73 2.0 D-jet dual port TB if it's available. I'll PM you my cell number - you can text me pics. Thanks, Kris |
brant |
I'm looking for a complete '74 2.0L D-jet throttle body. I've got a complete 73 dual port, no return spring that would functionally work Might have a complete 75 single port too... can double check tonight... but not 100% certain of this... but if the 74 did not have the return spring... then I don't have that one.... although a 75 with return spring should still work... as any of them between 73 - 76 could work/interchange into 1974 with capping one port sorry 74 is the one I may not have from a perfect concourse perspective. brant @brant I would be interested in the 73 2.0 D-jet dual port TB if it's available. I'll PM you my cell number - you can text me pics. Thanks, Kris Kris I’ll get you some pics and options today on 73 year tb Brant |
brant |
1973 dual port throttle body
$130 shipped in the US some previous owner put an RTV like plug on the butterfly idle hole I pushed on it with my finger nail and it should peel right off Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
brant |
Bump
Before they list elsewhere |
Puebloswatcop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,444 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region ![]() |
brant |
Bump
brant |
Bump
Lo-Fi Version | Time is now: 1st May 2025 - 11:35 PM |
