lowest tire pressure, used with larger tires ?? |
jimkelly |
Aug 23 2005, 09:48 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
What is the lowest air pressure you guys/gals use in your larger than stock (165R15) tires to get a nice ride?
Jimbo |
Joe Ricard |
Aug 23 2005, 09:52 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
35 psi with Mahles 195/50-15 Yoko AVS ES100 front
36psi Mahles 195/60-15 Goodyear GT4 (suck) rear 32 psi Fuchs 205/50-15 Kumho V700 all four 31 psi Diamond 15x8 205/50-15 Hoosiers all four |
jimkelly |
Aug 23 2005, 11:11 AM
so between 31 and 36 - between street and track.
thanks jim |
SirAndy |
Aug 23 2005, 12:30 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
25 on the street tires (225x50), 17 on the racing schlicks (23x9) ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
jimkelly |
Aug 23 2005, 12:40 PM
25 ???
So conceiveably with 245x50x15 and even lower number might be ok ??? Jim |
grantsfo |
Aug 23 2005, 12:42 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Depends on brand/model tire you are using.
SirAndy |
Aug 23 2005, 01:00 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) i found that my Nankang street tires (225/50x15) would stick the best at around 25lbs cold. they don't show any uneven wear either (besides my flatspots from a few AX) ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
markb |
Aug 23 2005, 01:08 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
26 front & 28 rear with 195's. I think that was factory.
Joe Ricard |
Aug 23 2005, 02:32 PM
I guess I like my tires hard.
I can't stand driving on wishy washy tires. If the side wall is rolling over then you are losing tread surface contact with the road. Come to think of most things are better hard. |
Eddie914 |
Aug 23 2005, 03:41 PM
Unregistered |
Front: 21 psi cold - 225/50/16 Yokohama A032R
Rear: 23 psi cold - 245/45/16 Yokohama A032R These track pressures. There is practically no sidewall deflection ... ever since the engine expired last weekend (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Eddie |
messix |
Aug 23 2005, 09:11 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
not true, letting the side wall flex keeps the flat tread on the ground as opposed to over inflated tires that can't flex. now bends over on its sidewall. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:55 PM |
