Stef914 |
human ![]() ![]() Group: Members Posts: 96 Joined: 21-July 21 From: Los Angeles Member No.: 25,745 Region Association: Southern California ![]() |
Hi all,
I've recently purchased a set of black steelies here: https://www2.cip1.com/acc-c10-6623-mb/ I'm trying to understand if 205/60 R15 tires will fit without rubbing the fenders. My car is stock, and I currently have stock Fuchs wheels, also with 205/60 R15 tires on. I know that the stock Fuchs are: 15 inches in diameter Have a width of 5.5 inches With a bolt pattern of 4x130 mm An offset (ET) of +40 mm An approximate backspacing of 109.85 mm or roughly 4.32 inches And I know that the steelies are: 15 inches in diameter With a width of 5.5 inches With a bolt pattern of 4x130 An offset (ET) of +25 mm An approximate backspacing of 108 mm or roughly 4.25 inches I unsuccessfully reached out to @80'soldschool! who in 2019 started a thread with the very same steel wheels but 6 inches wide rather than 5.5" and was running 195/55/15, but I wasn't able to get an answer from him... http://www.914world.com/bbs2/index.php?showtopic=339828 Anyway, I'm okay with mounting 195/55/15, but I'd rather go with 205/60 R15 if that works... So, to make a long story short, if any of you have the very same wheels with 205s on, would you be so kind as to let me know? This way, I'll be 100% sure they'll fit. Otherwise, I'm also wondering what your take on the correct size might be. As always, thanks so much for your help! |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,009 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Every car has different rear fender clearance. Hand assembled
So one persons answer does not guarantee it will fit your car Might fit 205 But no one on this board can answer that question exactly Depends on your car Only way to know is to try |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,424 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
What are your clearances now? If you decrease the offset by 15 mm (more than 1/2 inch) it will shift the wheels inward by that amount.
Jamie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,125 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States ![]() ![]() |
Hi all, I've recently purchased a set of black steelies here: https://www2.cip1.com/acc-c10-6623-mb/ I'm trying to understand if 205/60 R15 tires will fit without rubbing the fenders. My car is stock, and I currently have stock Fuchs wheels, also with 205/60 R15 tires on. I know that the stock Fuchs are: 15 inches in diameter Have a width of 5.5 inches With a bolt pattern of 4x130 mm An offset (ET) of +40 mm An approximate backspacing of 109.85 mm or roughly 4.32 inches And I know that the steelies are: 15 inches in diameter With a width of 5.5 inches With a bolt pattern of 4x130 An offset (ET) of +25 mm An approximate backspacing of 108 mm or roughly 4.25 inches I unsuccessfully reached out to @80'soldschool! who in 2019 started a thread with the very same steel wheels but 6 inches wide rather than 5.5" and was running 195/55/15, but I wasn't able to get an answer from him... http://www.914world.com/bbs2/index.php?showtopic=339828 Anyway, I'm okay with mounting 195/55/15, but I'd rather go with 205/60 R15 if that works... So, to make a long story short, if any of you have the very same wheels with 205s on, would you be so kind as to let me know? This way, I'll be 100% sure they'll fit. Otherwise, I'm also wondering what your take on the correct size might be. As always, thanks so much for your help! I have run 2 sets of Michelins in 205x65x15, no problem in back but mounted 12mm spacers in front to eliminate rub inside well at full lock. Car is completely stock with original 5.5"W steelies. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
185/70 15. Not much narrower than 195. Your speedometer should be correct or really close. The fitment on 5.5” steel rims is very good.
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,185 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
yes they will fit but you my experience the "jello" effect of the sidewall flexing over the rim of the tire because of the tire being wider than the rim
Hi all, I've recently purchased a set of black steelies here: https://www2.cip1.com/acc-c10-6623-mb/ I'm trying to understand if 205/60 R15 tires will fit without rubbing the fenders. My car is stock, and I currently have stock Fuchs wheels, also with 205/60 R15 tires on. I know that the stock Fuchs are: 15 inches in diameter Have a width of 5.5 inches With a bolt pattern of 4x130 mm An offset (ET) of +40 mm An approximate backspacing of 109.85 mm or roughly 4.32 inches And I know that the steelies are: 15 inches in diameter With a width of 5.5 inches With a bolt pattern of 4x130 An offset (ET) of +25 mm An approximate backspacing of 108 mm or roughly 4.25 inches I unsuccessfully reached out to @80'soldschool! who in 2019 started a thread with the very same steel wheels but 6 inches wide rather than 5.5" and was running 195/55/15, but I wasn't able to get an answer from him... http://www.914world.com/bbs2/index.php?showtopic=339828 Anyway, I'm okay with mounting 195/55/15, but I'd rather go with 205/60 R15 if that works... So, to make a long story short, if any of you have the very same wheels with 205s on, would you be so kind as to let me know? This way, I'll be 100% sure they'll fit. Otherwise, I'm also wondering what your take on the correct size might be. As always, thanks so much for your help! |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,072 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
My 4 lug rims are chrome aftermarkets I bought on sale in 83. They were made for 914's but were not selling any longer hence the sale. They are 5.5's with a 4 9/32's BS that I put 205's on. Not much room in the rear but never scuffed the face of the tire. And not for the lack of trying. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 5th July 2025 - 06:02 AM |
