| scottb |
Aug 25 2005, 06:07 AM
who wants a PEZ?! ![]() ![]() ![]() Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
i have made a couple of improvements to the drivetrain in the last week (clutch tube repair and rennshift) and now in the morning, when the car is cold, the clutch shudders when moving from a stop. i have to keep the rpms 3k+ and gently release to keep the shudder down. after about 10 minutes of driving, all is back to normal.
1) so, do i need to adjust the clutch cable now that the tube doesn't move? 2) am i going to have to relearn how to shift my car? 3) do i have something coating the clutch plate that takes a while to burn off each morning? (don't want it to be this one!) 4) all of the above? 5) throw it away and get a hyundai? thanks for the input...... |
| bd1308 |
Aug 25 2005, 07:10 AM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
i got some oil on my clutchplate and does the exact same thing....
i'm almost sure its oil...well on my car. |
| goose2 |
Aug 25 2005, 11:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
yup, sounds like oil on the plate (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
| scottb |
Aug 25 2005, 11:43 AM
crap!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) ok, i presume there are a number of places where the oil could be coming from but what are the most likely culprits? i do have a small leak at my oil pump that i have never gotten around to fixing but i doubt that would be the problem area. any input on where to look, what to look for and how much $ and how long to fix would be appreciated. looks like i may be parking for the season a little earlier than i had planned. got a feeling this could turn into one of those "while i'm in here, i may as well......." things. |
| goose2 |
Aug 25 2005, 11:55 AM
The most likely place for your leak (if that's what wrong) is the rear seal. See if you've got oil drippage at the bellhousing/motor joint. If it's not to bad, you can live with it until it's more convenient to fix. I've had cars with this problem last for years before it got real serious. The "backyard fix" is to drive along about 50 in 5th and floor it.....put enough pressure on the clutch to let it slip a bit (careful not to overrev). This can burn off the excess oil enough to give you a couple weeks relief. Do this too much and you'll likely need your flywheel resurfaced when you get around to tearing it down. DISCLAIMER.....this is definitely a "hack" temporary fix and assumes your clutch's days are numbered already. Try it once anyway to verify the cause of your problem.
Good luck |
| scottb |
Aug 25 2005, 01:49 PM
hack fix will be attempted on the way home!
funny thing is i went out at lunch and had one episode at a stop light then everything was smooth after that.... i am starting to think i have a bad case of crainial rectal impaction..... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) |
| goose2 |
Aug 25 2005, 02:14 PM
Also make sure all is well with clutch adjustment, motor mounts, CV's, axle bearings etc before assuming it's an oily disc..
| scottb |
Aug 25 2005, 03:48 PM
i had adjusted the clutch about a year ago. will have another whack at that and maybe go ahead and put my new clutch cable in just for shits and giggles..... and look for leaks while i am under there.
then..... see if i really have a problem.... thanks for the input folks.... i really want to make it to ECC and this would put a damper on that if a big problem..... |
| bd1308 |
Aug 25 2005, 04:25 PM
ecc? where's that....?
| goose2 |
Aug 25 2005, 04:40 PM
the etc. is next to the thingey.....it supplies smoke to the doo-dad
| bd1308 |
Aug 25 2005, 04:43 PM
no...that's where it is for a LUCAS car....
magic smoke does not exist anywhere on my car except magically coming off of the heat exchangers... ECC...like East Coast Classic?? |
| scottb |
Aug 25 2005, 05:34 PM
| scottb |
Aug 28 2005, 08:33 AM
let the car sit for a day and there is the tell tale bell housing drip that means an oil fouled clutch..... DOH! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
well i get to learn how to do a clutch now.... (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) |
Lo-Fi Version | Time is now: 12th March 2026 - 10:42 AM |
