> CD ignition box
Geezer914
post Aug 23 2024, 11:28 AM
Geezer914
What CD box are you using with a Mallory Unilite distributor. I tried a HiFire box but it was not compatible with the factory tachometer.
Replies(1 - 5)
rfinegan
post Aug 23 2024, 11:51 AM
Which Hi fire? I have one running on the uni lite and the tach out line runs the factory TACHOMETER on my 75 914 OK
Geezer914
post Aug 23 2024, 12:30 PM
Geezer914
I don't remember, what Hifire are you running? What wire from the box did you hook up to the tech? Are you running a tack adapter? Thanks.
rfinegan
post Aug 23 2024, 01:32 PM
I have the Mallory HIFIre VI al (rev limiter)model and the Unlit distributor for the trigger. The yellow wire is the tach signal and the coil has multiple pulses. NO tack signal buffer in use
https://documents.holley.com/6852m.pdf
rfinegan
post Aug 23 2024, 01:35 PM
pic
Geezer914
post Aug 23 2024, 01:56 PM
Geezer914
Thanks for the information!
- Lo-Fi Version Time is now: 14th April 2026 - 08:07 PM
