| DennisV |
Oct 22 2024, 07:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
While addressing a couple rust areas, I ran into a hard white substance that was painted over body color. It appears to be squirted or brushed on pretty thick. It wasn't applied with much care. I was able to chip, wire brush, or sand it out. I'm curious:
This is surrounding the heater vent tubes in the engine compartment. ![]() This is covering a half-circle cut-out in the driver floorboard just ahead of the pedals. ![]() I'm guessing the same stuff was used in the rear trunk over the screws holding the muffler shield bracket. |
| mepstein |
Oct 22 2024, 07:51 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Seam sealer. Used all over the car. Lots of modern day equivalents.
| Superhawk996 |
Oct 22 2024, 07:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
| Zeke |
Oct 22 2024, 10:57 PM
Never left, but not right.... ![]() ![]() Group: Members Posts: 393 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
There is a good polyurethane strictly for the seams. Wurth has it but so do a lot of body supplies. I used to use some stuff from the big box store but it was outlawed. The original PL brand. Hard to remove.
| DennisV |
Oct 23 2024, 01:17 PM
There is a brushable version too. Both sprayed and brushed were factory depending on location. Thanks for that lead. The product description sounds very appropriate for the application. I like there's brushable and gray options. I do see it states "Permanently flexible". If that's the case, if you paint over, won't the paint crack? I wonder if the original was also flexible...just not after 50 years. (IMG:style_emoticons/default/biggrin.gif) |
| mepstein |
Oct 23 2024, 01:57 PM
It is flexible but so is paint. Think about how all modern cars have plastic bumpers that flex a lot.
| Superhawk996 |
Oct 23 2024, 05:57 PM
Factory painted over it. Designed to be painted over.
No issues at all. Don’t judge me on the hillbilly AC holes patch job. I have the proper Restoration Design panel but needed these gaping holes filled in short term for a cross country move. Didn’t have time to do it to my satisfaction. (IMG:style_emoticons/default/hissyfit.gif) ![]() ![]() |
| nivekdodge |
Oct 23 2024, 06:10 PM
Member ![]() ![]() Group: Members Posts: 331 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
it says for primed and unprimed but i would surely primed before
| DennisV |
Jan 3 2025, 12:37 PM
Here is what the Wurth Brushable Seam Sealer looks like when applied. It has a super thick consistency. Doesn't even need to be stirred. Was pretty easy to work down into the crevice using a brush.
| 930cabman |
Jan 3 2025, 12:56 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
NAPA has a decent "brushable" product. A spray on will give you a closer to factory look
| technicalninja |
Jan 3 2025, 12:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Factory painted over it. Designed to be painted over. No issues at all. Don’t judge me on the hillbilly AC holes patch job. I have the proper Restoration Design panel but needed these gaping holes filled in short term for a cross country move. Didn’t have time to do it to my satisfaction. (IMG:style_emoticons/default/hissyfit.gif) ![]() ![]() Ha! That's impressive! His "half/ass hillbilly" job is one of the better repaired frunk floors I've seen... That looks "permanent finished" to me! It's NOT concours but that is nice! Now, seam sealing a temporary job that you INTEND to replace is a bit on the "Mental" side of things... (IMG:style_emoticons/default/ninja.gif) |
| Superhawk996 |
Jan 3 2025, 04:51 PM
Now, seam sealing a temporary job that you INTEND to replace is a bit on the "Mental" side of things... (IMG:style_emoticons/default/ninja.gif) Had to be seam sealed to withstand the rainstorms it went through going cross country. Now painting it that was certainly mental (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:08 AM |
