| Tobra |
Aug 28 2005, 02:05 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
The car has fog lamps, but it has some cheesy ass toggle switch that is snapped off anyway. The hole is in the right place, so I am thinking the PO perhaps went ot Radio Shack instead of the stealership, way back when. Would the switch that pelican lists as part # HEL-PEL-FSW work? It is only $15, which is a shocker to my untrained eye. It is a generic hella switch, no pic, but sounds similar to what it should be. No wiring kit, but the wires would be behind the dash anyway, and I am not a complete idiot(Semi stupid only)
| smooth_eddy |
Aug 28 2005, 02:10 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
I think the original fog light switches are NLA. You have to find them on eBay or ask here. They are expensive plus it is 30 years old by now. Not sure about the Pelican replacement. Does it look the same?
| Tobra |
Aug 28 2005, 02:17 AM
No pic, but the description sounds right, and the fog lamp switch in dear old Dad's '84 Carrera Cab looks like pics I have seen
| smooth_eddy |
Aug 28 2005, 10:16 AM
I just looked at Pelicans factory fog switch. It is NLA. I am sure the Hella works fine, just not a factory original. I would look for a factory switch. Being a fog switch, I would think you can find one in good shape. I don't think they get used much. I never use mine. Eddy
| johnmhudson111 |
Aug 28 2005, 05:24 PM
Member ![]() ![]() Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 |
Would the switches from a 911 work? Seems like they would and they might be eaiser to find. |
| Tobra |
Aug 28 2005, 06:40 PM
my thoughts exactly
| Mark Henry |
Aug 28 2005, 06:47 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
It's the same switch as the rear defogger, just the insert is different. They are quite common on old VW's... I think the bay window busses had them and I think the 4way flashers are the same switch in later beetles.
I do have a couple of inserts kicking around...might be a couple of weeks before I could send you one though. |
| scotty914 |
Aug 28 2005, 07:28 PM
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
you really dont need the stock switch... you could wire them to either the running lights or to the ign, so when what ever one youhave it wired to is on so are the fogs, ie like day time running lights
| flesburg |
Aug 28 2005, 09:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 22-November 04 From: Pontiac, IL Member No.: 3,162 |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Hello:
I have the switch you need in my spare parts box. Send me a pm. |
Lo-Fi Version | Time is now: 21st October 2026 - 03:28 AM |
