rear camber... how do I fix?, after new springs/shocks |
tat2dphreak |
Aug 29 2005, 01:15 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
a buddy followed me to the new house... I was in the teener and he was in his car...
he said my camber on the rear wheels is ALL FUCT! you can tell too much when the car is still, but he said that when the car is rolling it's VERY off... the tires look like "// \\" going down the road (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) I changed the rear shocks(bilstien) and springs(100-120# Welt.) could that have F'd the camber though?! if so, ho to fix? I plan to have a shop do a 4 wheel alignment anyway(after I replace the tie rod ends) will that fix it? |
SLITS |
Aug 29 2005, 01:17 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Ya need the shims that go under the trailing arm and an alignment shop, but since they go like / \ you can be a racer with negative camber like that. (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif)
tat2dphreak |
Aug 29 2005, 02:54 PM
ok... so did the shorter springs cause this? or was this issue already there?
bondo |
Aug 29 2005, 03:21 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Yes, shorter springs will do that. The trailing arm pivots at an angle, so ride height affects camber and toe. Always realign after a ride height change.
Lo-Fi Version | Time is now: 1st June 2024 - 05:35 AM |
