Centercap emblems, Need some clarification and advice |
ninefourteener |
Jul 30 2003, 10:12 AM
Perfectly Normal Guy :) Group: Members Posts: 1,216 Joined: 3-June 03 From: St. Louis, MO Member No.: 779 |
I have a set of the typical 4 lug fuchs, with the original centercaps, same ones used on the pedrinis and mahles.
The sides are perfect on all 4, but the flat surfaces are a little "squirrelly". I thought getting a set of those adhesive-backed Porsche emblems would both cover the ugly part, as well as add a nice touch to the car. My question: I've seen a couple of different kinds and sizes on the bay. Anyone bought a set of these before? Did they fit ok? Do you have pics? I'm at work, and the teener is at home, so I can't go out and measure.... anyone already done the research on this? Which ones would be better to buy?? Here's the links: 1.75 inch emblems: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33744 2.0 inch emblems http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33643 Or aftermarket caps with emblems, 2.5 inch hole http://cgi.ebay.com/ebaymotors/ws/eBayISAP...gory=43961&rd=1 Any help would be greatly appreciated!! |
Qarl |
Jul 30 2003, 11:25 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Third ad... 2.5" is the size of the hole the entire cap plugs into.
I think, if you have factory wheels with the factory cap, I think the 2" is the one you need. If it is aftermarket (Repros or Rivieras or Empis) then it's the 1.75". Just measure your cap and that will tell you... Karl |
ninefourteener |
Jul 30 2003, 12:04 PM
They are the original caps.... I just went home for lunch and measured them. Seems like the 2 icks would hang over the edge.
the 1.75 might be a little small though. |
Targa |
Jul 30 2003, 01:40 PM
V Member Group: Members Posts: 180 Joined: 26-December 02 From: San Mateo, CA Member No.: 18 |
The 2 inch ones will hang over the cap. I got a set of the 1.75's and they were perfect. though I would advise you to have the flat surface as flat as possible. I kind of stuck mine on and will probably need a new set one day since the caps are not flat.
ninefourteener |
Jul 30 2003, 02:10 PM
Do you have a pic of how it looks??
Targa |
Jul 30 2003, 05:15 PM
Sorry I don't have one available, but I did look at all of the links you posted and I can only say that it fits perfect.
Jeroen |
Jul 30 2003, 06:45 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Lo-Fi Version | Time is now: 5th June 2024 - 05:36 AM |
