> Wheel Spacers on Flared Fenders
HDC
post Mar 14 2025, 08:26 PM
The restoration of my 914-6 is moving along well. The car has steel flared fenders and a set of Fuchs 6x15 will be installed, but I believe I need some spacers to move the wheels outward a bit.
I believe M471 cars used 6x15" wheels and 21mm spacers, am I correct?
I also need longer wheel studs, what is adequate for a 21mm spacer, a 70mm stud?
Thanks
Henry
Attached Image Attached ImageAttached Image
Replies(1 - 12)
dr914@autoatlanta.com
post Mar 15 2025, 11:05 AM
the m741 models used 21mm wheel spacers, yes with 6 inch fuchs alloy wheels, the 914 21mm wheel spacers with 7 inch wheels
HDC
post Mar 15 2025, 02:09 PM
QUOTE(dr914@autoatlanta.com @ Mar 15 2025, 11:05 AM) *
Thanks!
Chris914n6
post Mar 15 2025, 07:23 PM
Jackstands are my life.
I used the 21mm spacers and studs off the rear of an early 944. I think they are 80mm but not sure at this time.
I'd put something wider than 6" on a flared car, or what's the purpose. And if you're not into exact replica I'd do 16" for the shorter sidewall and tire choices. 205/55-16 is stock Boxster fronts and a very common size.
jfort
post Mar 15 2025, 10:57 PM
I have a factory 6. It had 16” Fuchs when I bought it. I added the steel flares. I have front wheels 7x16, tires 225/45
74mm studs 21mm 944 spacers
bdstone914
post Mar 16 2025, 05:42 AM
bdstone914
@HDC
I have the spacers and maybe the studs.
But why flare and only go 6"?
Those will git without flares.
Tom1394racing
post Mar 16 2025, 08:56 AM
On my GT project with steel flares we are planning on 15X7 fronts and 15X9 in the rear.
HDC
post Mar 16 2025, 12:04 PM
Thanks for the comments on the 6" wheels, I also have a set of 7"x15 and a 7"x16. I will try those on for size. I think I like the 15s more than the 16s, because the 16s are all black
My current studs are 45mm long, so if I add 21mm spacers, I should be OK with 66mm studs?
I have seen the spacers from 944s, those are 21mm, and plenty of availability. I might g with those
Thanks again
Henry
post Mar 16 2025, 12:34 PM
Resident German
After years of juggling different sets of wheel spacers and wheel studs for different sets of wheels (AX, track, street) i finally had enough and added 100mm wheel studs on all 4 corners.
Now i have one set of spacers for the street and one set of spacers for track/AX.
Easy to swap around when needed.
I never looked back ...
(IMG:http://www.914world.com/bbs2/uploads/post-179-1330326828_thumb.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1330327329_thumb.jpg)
mlindner
post Mar 16 2025, 02:00 PM
QUOTE(bdstone914 @ Mar 16 2025, 06:42 AM) *
@HDC
Yup, I'am with Bruce Stone, Why. Flared fender are meant for larger tires/ Performance.
VaccaRabite
post Mar 17 2025, 05:31 AM
En Garde!
QUOTE(mlindner @ Mar 16 2025, 04:00 PM) *
@HDC
More rolling resistance. More expensive tires. Not a stock size, or won't fit a stock wheel. Maybe harder to find. There are lots of reasons.
Zach
post Mar 17 2025, 05:46 AM
914-6 GT in waiting
If you have a relatively stock 4, six inch wheels will probably give you a better driving experience than 7 & 8’s with wide rubber.
HDC
post Mar 17 2025, 01:41 PM
One other reason is that the flares were in the car when I bought it, and I'm trying to use one of the wheel sets I already have instead of buying a new set. This is how the car looked with the 7x15 before going to the body shop.
- Lo-Fi Version Time is now: 9th May 2025 - 06:20 AM
