gnomefabtech |
Member ![]() ![]() Group: Members Posts: 147 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None ![]() |
Hello all-
So, I'm finally able to turn my attention to the suspension on my car now that it's running. The car was hacked for a v8 when I got it and I have instead done my Hayabusa engine swap. I'll have to make a separate thread on the adaptor setup, but it's mounted north south and uses the original 901 trans. Dynos at about 300whp with turbo. 2k lbs overall weight. Narrow body. The PO added some crazy stiff rear springs on coilover sleeves and they need to go. Also the front is way too stiff. It's all 911 front suspension and brake parts. Questions: I'm thinking about 140# springs in the back, but how long a spring should I use. 14"? 12"? Helper springs? In the front I think it might have like 21mm bars, and that's way too stiff. Are normal 19mm 911 bars soft enough for a street driven 914? Or are there thinner 911 compatible bars? Thanks! |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,028 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,668 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
I went down to 110lb springs in the rear of my six conversion. As far as I know, front are stock 914-4 torsion bars. I like this combo for street use. The 914 will actually take some bumps and potholes in stride instead of bouncing and skipping across the road.
I think it really depends on your intended use for the 914. Drive it or race it? I ditched beating the crap out of myself, passenger and car a long time ago. (IMG:style_emoticons/default/driving.gif) |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,982 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
@gnomefabtech
Hey dude, I’m from LA and know there are some great roads in the county. If your are an enthusiastic driver, and prefer your car remains flat under any situation then the 140 rear and 19 mm front is a capable setup.A 19mm and 17mm sway bars work well with that. If you prefer to motor under more comfortable conditions Root Werks setup sounds nice. |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,667 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
@gnomefabtech Hey dude, I’m from LA and know there are some great roads in the county. If your are an enthusiastic driver, and prefer your car remains flat under any situation then the 140 rear and 19 mm front is a capable setup.A 19mm and 17mm sway bars work well with that. If you prefer to motor under more comfortable conditions Root Werks setup sounds nice. Ive go what Shivers mentions. works well at auto-cross/hill climbs but is still street compliant. Love it. Mark ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,876 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Make sure you identify your A-arms before buying torsion bars. 911 have a different spline count than 914 and are not interchangeable
gnomefabtech |
Great replies.
I am one to set stuff up pretty soft and get the most out of the suspension that way. I had no idea that the stock rates were so soft! Sounds like even 100# springs would be pretty firm. Also, my engine is much lighter than even a stock 4 cyl 914. My dream is to have the springs work all the way to full droop, because I've found that having active droop spring rate really helps with corner exit grip on an open diff.. I'm pretty sure it's all 911 stuff up front so I'll need 911 torsions. Are the thinnest 911 torsions 19mm? Or are there thinner ones? Has anyone tried progressive rear springs? |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,931 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
Note that the torsion bars on both the 914 and 914-6 were 17.9mm (914-6 has
the splines for the 911 front end). I haven't seen anyone making < 19mm new parts, but you could find some used ones. |
Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,922 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
I have 140 lb. springs in the rear and 19mm torsion bars up front. Nice firm set up and not too stiff.
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,321 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
I like soft suspension with sway front and rear it’s much easier on my L3 L4
mepstein |
Great replies. I am one to set stuff up pretty soft and get the most out of the suspension that way. I had no idea that the stock rates were so soft! Sounds like even 100# springs would be pretty firm. Also, my engine is much lighter than even a stock 4 cyl 914. My dream is to have the springs work all the way to full droop, because I've found that having active droop spring rate really helps with corner exit grip on an open diff.. I'm pretty sure it's all 911 stuff up front so I'll need 911 torsions. Are the thinnest 911 torsions 19mm? Or are there thinner ones? Has anyone tried progressive rear springs? The smallest 911 torsions are ~18.9 while the standard 914’s are ~ 17.9 |
gnomefabtech |
What did those 18.9 bars come in? Short wheelbase 911?
gnomefabtech |
Do any of you know roughly what a type 4 weighs fully dressed? Might help me guess at my rear springs. Hayabusa weighs around 220# with turbo, pumps, oil tank, and stuff.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,949 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
The common answer is 250. With close to 50/50
Any weight moved forward in a 4 helps the handling And a six close to 400 Messes with the ratio of F/R significantly |
gnomefabtech |
Does anyone know the motion ratio of the rear suspension? Seems close to 1:1.
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Here is a question to think about If you are running a 2000 lb car and doing so on the street why would you need rear springs that are 55% stiffer than the GT ran? (IMG:style_emoticons/default/agree.gif) That! 100% in the 90s people over sprung the crap out of these things in addition to using the dog (IMG:style_emoticons/default/stromberg.gif) poly bushings that just caused control arms to bind up. It "feels" like it handles better because its more responsive but both your grip and your ride quality suffer. Unless you are regularly taking corners at 100+ MPH you are probably better off keeping it on the softer side. |
JamesM |
Do any of you know roughly what a type 4 weighs fully dressed? Might help me guess at my rear springs. Hayabusa weighs around 220# with turbo, pumps, oil tank, and stuff. My flared 4 weighs 1950 (44% Front / 56% Rear), but i've done some things (IMG:style_emoticons/default/smile.gif) Stock 2200-2450 depending on the year and options. I wouldn't go over 140lb in the rear. I have that on my autocross car currently and am thinking about dropping even lower. Stock front torsion bars, 19mm Tarret sway bar set full soft. |
captain awesome |
Newbie ![]() Group: Members Posts: 35 Joined: 4-July 24 From: Bella Vista, AR Member No.: 28,217 Region Association: None ![]() |
Are most of the softer 100 lb recommendations with the caveat that you are running a rear sway bar? I was considering 140lb to start since I don't have one but this thread is making me reconsider. Also interested in the spring length as I too would like plenty of droop travel.
slivel |
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 528 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California ![]() |
Does anyone know the motion ratio of the rear suspension? Seems close to 1:1. This is what I came up with: MR = Motion Ratio Rear MR(SQ) = 1.68 MR*MR d1 = spring to arm pivot d2 = hub to inner pivot 1.296296296 Rear Trailing Arm Motion Ratio d1 = 17.5 d2 = 13.5 914 trailing arm |
flxzcat |
Newbie ![]() Group: Members Posts: 47 Joined: 13-June 11 From: lake forest socal Member No.: 13,188 Region Association: None ![]() |
My new to me 914-4 is 1825lbs weighed last week on Longacre scales and a 44%-56% balance (I like adding lightness)
Somehow, I got talked into 21mm hollow bars up front and 250lb coils in back. The car is way too stiff on the street and I consider myself a hard-core racer canyon carver type. I will soon be changing to 19mm front and 180lb rear. |
Lo-Fi Version | Time is now: 9th May 2025 - 04:38 PM |
