> Will 205/65R15 tires fit?, Currently have BFGoodrich Comp TA 205/50VR15 on 2-liter wheels
Alden
post Apr 17 2025, 05:03 PM
My Comp TA's are well past the "best by" date. I want to go larger in diameter to bring down the RPM's. If 205/50 fit (no rubbing) will 205/65 fit? The tire is just getting taller not wider, correct?
Replies(1 - 5)
Jamie
post Apr 17 2025, 07:16 PM
QUOTE(Alden @ Apr 17 2025, 03:03 PM) *
I have run 3 different brands of 205x65x15 tires on original steel wheels over the years without significant problems, speedo very close to stock diameter readings. Added 12mm spacer to the front to eliminate inside well rub at full lock, back fits just fine without any fender pulling.
Alden
post Apr 29 2025, 07:09 PM
205/70 installed no rubbing issues (8.2-inch section width, 26.3-inch overall diameter). 5th gear 3000 RPM is 71 MPH per GPS, 69 MPH speedometer. Attached Image
Ottomotion
post Apr 29 2025, 07:48 PM
Both of mine have 205/60/15 and no rubbing....
Alden
post Apr 29 2025, 08:19 PM
Left rear is close, but no rub, plenty of room on right rear. Attached Image
Attached Image 205/70 vs 205/50
Dave_Darling
post May 1 2025, 01:44 AM
914 Idiot
Yes. Ish.
The numbers for tire sizes are all "nominal", but the actual measurements can vary from brand to brand and sometimes vary within a tire model!
In theory the 205/65 should be no wider than 205/50. In practice, they may be wider or narrower. Hopefully if they are, it isn't enough to matter.
--DD
- Lo-Fi Version Time is now: 7th September 2025 - 11:18 AM
