> Flasher relayl - Blue/white wire, Not sure what is does now… after
jim_hoyland
post Apr 23 2025, 07:27 PM
Get that VIN ?
I have added left and right turn signal lights to my early tach. While trying to follow Spokes wiring diagram and using the BLUE / WHITE wire to each bulb; no flashing occurred. When i replace the blue/white wire with a ground it works fine.
Question is whether the flasher relay is working right. Everything else that’s supposed to flash is fine
@spoke
Replies(1 - 2)
Spoke
post Apr 24 2025, 10:29 AM
Jerry
Jim,
The blue/white wire is the original configuration. If you're adding L and R indicators in the tach then just ground the common connection of the indicators. Just find a local ground on the tach for the indicators.
jim_hoyland
post Apr 24 2025, 04:43 PM
Get that VIN ?
QUOTE(Spoke @ Apr 24 2025, 09:29 AM) *
Jim,
Thanks: we did what you suggested and the dash indicators work great ! (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 9th May 2025 - 10:24 PM
