> Pre run engine before installing
bajafreaks
post Apr 26 2025, 12:35 PM
I'm quite aways from having my engine completed but just wondering if there is any big advantage to pre running it before installing. It will be on carbs.
Replies(1 - 7)
technicalninja
post Apr 26 2025, 12:52 PM
Absolutely!
Especially a fresh engine!
Bunch easier to re-adjust valves and re-torque head nuts after first full heat cycle if the puppy is out of chassis.
Oil leaks are easier to spot/fix.
Good/bad memories will be made...
bajafreaks
post Apr 26 2025, 01:41 PM
QUOTE(technicalninja @ Apr 26 2025, 11:52 AM) *
Absolutely!
Kinda what i was thinking, exactly.
I guess it cant be that difficult to hook up a temp fuel pump, battery, etc.
The transmission would be attached anyway before installing into the car.
Is there anything I'm missing?
post Apr 26 2025, 03:07 PM
914-6 GT in waiting
We run almost all our engines on a test stand before installing in the car. Easier to spot leaks, noises, etc. you can put a 914 engine and trans on a pallet and run it. AIM a fan at the engine if you run it for more than a minute
Jack Standz
post Apr 27 2025, 06:06 AM
Yes, a couple ratchet straps and a pallet works.
You should remove the alternator belt (or hook up a voltage regulator temporarily), as you'll not want to potentially destroy the alternator.
bajafreaks
post Apr 27 2025, 09:01 AM
QUOTE(mepstein @ Apr 26 2025, 02:07 PM) *
Do you do the cam break in as well ?
NARP74
post Apr 27 2025, 12:40 PM
This guy makes some stuff that helps. Maybe if you are only doing one, not worth it...
https://zalexindustries.com/
930cabman
post Apr 27 2025, 12:51 PM
In addition, I prime the oil system by cranking it over to achieve oil pressure before starting a new engine.
keep us posted with your progress
- Lo-Fi Version Time is now: 24th November 2026 - 12:03 AM
