Kemo |
Newbie ![]() Group: Members Posts: 24 Joined: 8-February 06 From: Austin, TX Member No.: 5,546 ![]() |
All,
i have the top end off my 73 1.7 and im going to the 1.9 slip fit from Auto Atlanta and i was wondering about the different lifter options. the ones i have look really good without any visual damage. But im a little worried about how "springy" they are. i took a push rod and just pressed down a few of the lifters and was wondering if this is something i should address while things are apart. Should i buy new stock lifters? What is a "solid" lifter? (sounds dangerous) not sure what a hydraulic lifter is...any info is very helpful. this is my first go round with a 4cylinder 914 motor. thanks!! Steve |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,876 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
914’s should have solid lifters. Hydro lifters are for lower revving bus engines.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,949 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Sounds like hydraulic lifters are on your engine
You have to reuse them in the exact sequence they were for matched wear You can’t put new lifters in without changing the cam,rebuilding the bottom end You are giving up performance. Especially at higher rpm with hydraulic lifters |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,070 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
camshafts and lifters work closely and can degrade quickly if not installed correctly. Consider purchasing a kit, matching cam/lifters. This is one place where you do not want to save a couple $$
Kemo |
ive got them bagged and marked so i can reinstall in the same hole...it sounds like i would need to install a new cam if i replace any of the lifters. is there a way to "test" the lifter? like i said, i just kinda pushed down on the springy side of things and started pondering all this.
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,884 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
They don't have much resistance until the oil pumps them up.
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,668 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
They don't have much resistance until the oil pumps them up. (IMG:style_emoticons/default/agree.gif) The "test" is to simply see if you can push down and it comes back up. Lots of times sludge will prevent lifters from pumping up in a timely or not at all fashion. |
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 717 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
Test them by putting a lifter in a plastic cup with enough oil in it to cover the top of the lifter. Push the top of the lifter down a few times with the pushrod. That should pre-load the hydraulic section of the lifter with oil and the resistance should become stronger after you have pushed down on the pushrod a half dozen times. If the resistance doesn't increase, then the lifter is worn out and needs replacement.
Test each lifter in the same manner to see if they build up resistance. If they all do, you can re-use them with that cam. However, as others have stated, you will be leaving a lot of the performance to be derived from the larger displacement pistons and cylinders on the table. |
Lo-Fi Version | Time is now: 9th May 2025 - 07:11 PM |
