| reynoldslh |
May 9 2025, 11:44 AM
Newbie ![]() Group: Members Posts: 4 Joined: 2-October 23 From: Portugal Member No.: 27,623 Region Association: Europe |
I am trying to troubleshoot what I think is a lazy temperature gauge response on my car (European 1973 914-4 with combo instrument) which has been in storage for far too long.
The temperature needle does not go above about 1/4 way across even with the engine warm. Either that´s normal, or the gauge is out of calibration, or there is a problem with the sensor, or possible combination of all of the above. What is the expected resistance range of a working temp sensor in the sump? I suspect its the long snout type 200C sensor which is fitted since the taco plate has the angled sensor mount. Also how to test the temperature gauge itself? |
| Superhawk996 |
May 9 2025, 01:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,858 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Duplicate
| Superhawk996 |
May 9 2025, 01:14 PM
Pretty normal for an early gauge with the proper 200C sender
![]() Combo (see Fig 3) ![]() Test via boiling water or in oil with secondary thermometer. |
| Lockwodo |
May 9 2025, 01:48 PM
Member ![]() ![]() Group: Members Posts: 239 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California
The oil temp gauge on my ’74 2.0 barely moves when the car is warmed up, never gets even 1/8 of the way across the dial.
| 914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,491 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
CHECK wire from sender to plug under battery shelf. Probably has high joint (broken wires) under sheath.
| emerygt350 |
May 9 2025, 02:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,623 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Same here. Only time the gauge moves up past 1/4 is when it's hot out and I have been driving hard. Like climbing long long high hills on the interstate hard.
| 930cabman |
May 9 2025, 04:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,691 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Confirm with an infrared point/shoot
| bkrantz |
May 9 2025, 07:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,711 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Yup. Stock "normal" looks low, and takes forever to get there.
| reynoldslh |
May 10 2025, 06:24 PM
Pretty normal for an early gauge with the proper 200C sender Test via boiling water or in oil with secondary thermometer. Thanks Superhawk996, I had seen these useful graphics on another post which made me wonder about my situation. You´ve helped confirm it. Cheers |
| reynoldslh |
May 10 2025, 06:30 PM
| reynoldslh |
May 10 2025, 06:35 PM
Thanks to all for confirming that my temperature gauge is probably working just fine!
Lo-Fi Version | Time is now: 7th June 2026 - 04:06 PM |
