| jim_hoyland |
May 12 2025, 08:24 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,962 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Bob and I tested for a parasitic drain today; about a week ago engine wouldn’t turn over Hadn’t left anything on.
Today’s test we got 3.28 micro amps . The meter was connected to the battery neg post and system ground. Seemed ok ? |
| worn |
May 12 2025, 08:40 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,517 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest
Bob and I tested for a parasitic drain today; about a week ago CDR wouldn’t turn over Hadn’t left anything on. Today’s test we got 3.28 micro amps . The meter was connected to the battery neg post and system ground. Seemed ok ? That doesn’t seem like much. Do you have a clock? Also, I am a bit slow in the uptake. What does CDR mean? |
| dtmehall |
May 12 2025, 08:43 PM
Member ![]() ![]() Group: Members Posts: 224 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
i think that a lot more background info would help.
why are you measuring for this? the reading you gave is nothing how long do you leave the car sitting? |
| jim_hoyland |
May 12 2025, 08:52 PM
Typo : CDR, meant car engine
The car normally get trickle charge when not driven and I drive about 50 miles a week. The morning it wouldn’t start, I didn’t have the trickle charger on. |
| L-Jet914 |
May 12 2025, 10:41 PM
Member ![]() ![]() Group: Members Posts: 370 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
How old is the battery? Was the battery fully charged when performing your parasitic draw test? A discharged battery will cause inaccurate readings. When you mean microamps, do you mean milliamps? 3.2mA is very low and not enough to kill a battery. Where as 3.2microamps is 0.0032mA (milliamps). On today's vehicles 50mA or less is nominal. Anything higher and the battery will discharge in about a week or less. I've always tested parasitic draw by connecting the positive lead to the positive battery post and then the negative lead to the positive battery cable, and then remove the positive battery cable. Grant it you can do it on the negative side with the negative lead on the negative battery terminal and the positive lead on the negative battery cable.
| jim_hoyland |
May 13 2025, 05:51 AM
Optima 34R, at least 10 yr old, test was done on fully charged battery.
| ctc911ctc |
May 13 2025, 06:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
How old is the battery? Was the battery fully charged when performing your parasitic draw test? A discharged battery will cause inaccurate readings. When you mean microamps, do you mean milliamps? 3.2mA is very low and not enough to kill a battery. Where as 3.2microamps is 0.0032mA (milliamps). On today's vehicles 50mA or less is nominal. Anything higher and the battery will discharge in about a week or less. I've always tested parasitic draw by connecting the positive lead to the positive battery post and then the negative lead to the positive battery cable, and then remove the positive battery cable. Grant it you can do it on the negative side with the negative lead on the negative battery terminal and the positive lead on the negative battery cable. (IMG:style_emoticons/default/agree.gif) |
| Superhawk996 |
May 13 2025, 07:57 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,592 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Just not enough info. Details matter.
| 76-914 |
May 13 2025, 08:31 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,828 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Jim, This is what LJet914 was describing but with pics. (IMG:style_emoticons/default/biggrin.gif)
https://www.youtube.com/watch?v=-uW5e-sLK0o But do this test 1st. Especially since it is an old battery! https://www.youtube.com/watch?v=yRvlS6EC15U |
| jim_hoyland |
May 13 2025, 08:56 AM
Thanks Kent (IMG:style_emoticons/default/smile.gif)
The second uTube is very good; it analyzes a dozen battery testers and is a big help[. I ended cup ordering an Angel for $37.00. I think this tester will tell the true condition of myun10 yr old Optima 34R |
| davep |
May 13 2025, 09:21 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,344 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Considering a 10 year old battery, I would guess that the battery has lost most of it capacity. I noticed that on my own car one time when it would not run an electric cooler for longer than an hour (@5 amps) but would always start the car. When I replaced the battery I could run the cooler for 8 hours and still start the car.
| JOEPROPER |
May 13 2025, 10:05 AM
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,208 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States
When tested correctly anything below 0.05 Amps is acceptable. !0 year old battery should be replaced. I would replace the battery and retest. Test alternator output too and don't forget to check all critical connections.
| jim_hoyland |
May 13 2025, 10:53 AM
Good tips( thank you (IMG:style_emoticons/default/smile.gif)
| Dave_Darling |
May 13 2025, 07:21 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,301 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Did you just put the probes on the negative battery post and the engine ground? With the battery ground strap connected?
Doing this will give you a very low reading that is basically meaningless. You need to disconnect the battery ground, then put the ammeter in between the battery post and a chassis ground. The most convenient one being the negative battery terminal. Unless you're using a very fancy "amp clamp" type of meter, an ammeter will only measure the current that is passing through it. --DD |
| L-Jet914 |
May 13 2025, 07:32 PM
Optima 34R, at least 10 yr old, test was done on fully charged battery. The oldest Optima I had in my car was 11yrs old before it no longer accepted a charge. I always put it on a battery maintainer after I parked my 914 in my garage for the day. I replaced it and that one only lasted about 2 years before I replaced it under warranty. I am on my 3rd Optima yellow top. I think your 34R is just tired due to age and it's time to replace it. 10 years is pretty good for a battery. |
| jim_hoyland |
May 13 2025, 07:47 PM
Did you just put the probes on the negative battery post and the engine ground? With the battery ground strap connected? Doing this will give you a very low reading that is basically meaningless. You need to disconnect the battery ground, then put the ammeter in between the battery post and a chassis ground. The most convenient one being the negative battery terminal. Unless you're using a very fancy "amp clamp" type of meter, an ammeter will only measure the current that is passing through it. --DD OK; the battery ground was disconnected 1st, one probe was set on battery neg post, the other probe was attached to the battery’s ground cable. |
| Root_Werks |
May 14 2025, 05:07 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,863 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Did you just put the probes on the negative battery post and the engine ground? With the battery ground strap connected? Doing this will give you a very low reading that is basically meaningless. You need to disconnect the battery ground, then put the ammeter in between the battery post and a chassis ground. The most convenient one being the negative battery terminal. Unless you're using a very fancy "amp clamp" type of meter, an ammeter will only measure the current that is passing through it. --DD OK; the battery ground was disconnected 1st, one probe was set on battery neg post, the other probe was attached to the battery’s ground cable. Yup, that's correct. Make sure NOT to turn on headlights or other large draw items. You'll either pop the fuse in your multimeter or burn it. It should say what max amp it can read. Had a parasitic drain on an L-Jet 2.0 many years ago. Wound up being the double relay. Just had to unplug relays and remove fuses one at a time until the drain went away. |
| jim_hoyland |
May 14 2025, 05:31 PM
Got my battery tester today and made a their preliminary test:
Attached thumbnail(s) |
| ClayPerrine |
May 15 2025, 11:20 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I made this for an Okteenerfest tech session. It works.
It is cheap, and will find that pesky draw in your car. Just install it, and hook up your DVOM. Then start removing fuses. If the draw is still there, start by disconnecting the 4 red wires from the positive battery post, Hook them up one at a time. When the draw comes back, see what still works to find out which circuit it's using. I have the black Fluke current probe, and while it is very accurate, I find it always has dead batteries when I need it. I have put in the home made current shunt, and the Fluke amp probe to compare them. They are within 1% of each other when tested. |
| ClayPerrine |
May 15 2025, 11:25 AM
If you want the MS Word copy of the document, PM me your email and I will send it to you.
Lo-Fi Version | Time is now: 14th December 2025 - 12:22 PM |
