> Correct pressure plate for a six
sixaddict
post May 13 2025, 05:32 AM
Looking for new pressure plate……one listed for 914-6 is also shown as part of “kit” for 4 cylinder cars so not sufficient for HP of engine.
Anyone able to give me part number for what I need without going exotic.
Thanks
Replies(1 - 8)
Tom1394racing
post May 13 2025, 06:42 AM
I went with a Kennedy Engineering clutch kit for my 3.2 conversion.
Tom1394racing
Please delete.....duplicate post
Steve
post May 13 2025, 07:38 AM
QUOTE(sixaddict @ May 13 2025, 04:32 AM) *
Thanks
2.0 four is the same for 2.0 six. I put a 2.0 six flywheel on my 2.7 and used the same clutch. No slippage or issues. Nine bolt flywheel for 3.0 and above requires a KEP setup.
Superhawk996
post May 13 2025, 08:02 AM
Clutches and pressure plates don’t care about horsepower. Torque is what matters
914/6 2.0L was about 120 lb-ft
914/4 2.0L was about 116 lb-ft
This is why the /6 and /4 share the “kit”
Sachs and others publish the torque specs of their hardware if you’re doing something outrageous. Chart below is for standard clutch materials. Other friction and pressure plates available if you need more capacity. Attached Image
Max torque: 250Nm =184.391 lb-ft
sixaddict
post May 13 2025, 08:42 AM
Thanks for input.
davep
post May 13 2025, 09:25 AM
914 Historian
Originally the 914/4 friction disc had 4 springs, and 914/6 had six springs. but since the specs were so similar it made sense to just stock a 914/6 disc and PP to use with both and some 911's.
sixaddict
post May 13 2025, 05:55 PM
Makes sense
porschetub
post May 16 2025, 03:43 PM
QUOTE(sixaddict @ May 14 2025, 11:55 AM) *
Makes sense
Sure you are aware the prices for these are really over the place ,I spent a while searching and bought NOS one off ebay for a great price ,cheers.
- Lo-Fi Version Time is now: 11th August 2025 - 02:02 AM
