Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Maybe I've just made too much stuff. I've made this some time ago but can't recall where it went. If I recall correctly, it was a paper gasket originally.
The 4 radius notches are the defining feature. Help me play guess that seal! Attached thumbnail(s) ![]() |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,969 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
hard to guess the OD
but the CV gaskets have little cut outs ... so maybe CV? |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,692 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
hard to guess the OD but the CV gaskets have little cut outs ... so maybe CV? (IMG:style_emoticons/default/agree.gif) |
BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 645 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
What is the size (ID/OD) of the gasket?
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,874 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Late model gas cap seal?
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,268 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
CV gasket would have 6 indents, not 4, no?
I edited my previous guess. I feel like I just saw this gasket recently but can't place it. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,970 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Edit. Nope too narrow for that
Could it be a fuel filler gasket and the holes did not get punched? They are about 4" @Mikey914 Attached thumbnail(s) ![]() |
Mikey914 |
About 2" in Dia.
sb914 |
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,510 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California ![]() ![]() |
Fuel sender gasket.
What do I win ? |
Root_Werks |
Mikey914 |
Now I'm going to have to check a cap, just need to locate one that I haven't swapped out. We have a slightly thicker version we made, that I"m currently using. Perhaps it's a copy of the original we did in Viton.
bdstone914 |
Steve |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,833 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Seems to me you should win the said gasket! (IMG:style_emoticons/default/smile.gif)
Mikey914 |
Ok, that explains it. We switched to a thicker Viton seal that actually seals very well.
What did you win ? Hit me up if you want something you can use, I ll drop it out to you. Say something in the $30 range. Sound fair? Mark |
Steve |
Ok, that explains it. We switched to a thicker Viton seal that actually seals very well. What did you win ? Hit me up if you want something you can use, I ll drop it out to you. Say something in the $30 range. Sound fair? Mark Thanks Mark!! Or just a beer at the next event!! (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 3rd June 2025 - 04:14 AM |
