> Speedo gear seal - How do I get it in?
PaIsa
post May 15 2025, 05:14 AM
I am still dealing with a small leak at my speedo gear at the back of the transmission.
I currently have the original bushing with only 1 o-ring and I have available the update version with 2 o-rings but I need to replace the seal in this one.
The problem I have is to get the seal to go in the bushing. It is a very tight fit and I already destroyed I seal trying. What is the method to get this in. Freeze the seal? Heat the bushing? Combination of both? Something else?
Replies(1 - 5)
bdstone914
post May 15 2025, 07:28 AM
bdstone914
Use a long 10mm bolt, washer and nut to act as an install tool
PaIsa
post May 15 2025, 07:31 AM
QUOTE(bdstone914 @ May 15 2025, 07:28 AM) *
Using this set-up to press in the seal? I guess that adding some gear oil will help in the seal getting in without being damaged.
Nogoodwithusernames
post May 15 2025, 09:10 AM
If you don't have a press you can fake it with a bench vise or drill press. Some lube on the seal is always good too.
914sgofast2
post May 15 2025, 10:21 AM
Use some silicon grease on the seal. It can be found on Amazon. Silicon grease makes tight seals slide right in.
bdstone914
post May 16 2025, 09:19 AM
bdstone914
How i do it.
And some lube on the bore and seal
- Lo-Fi Version Time is now: 3rd June 2025 - 06:34 AM
