SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,697 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
I'll try and simplify this- swapping engines in my '73 2.0 which I've had for 25 years (and known since new) from my '71 which I've had since new. The "1.7" has been extensively modded over the years and is a better engine than the OEM '73. Has Webers and Webcam.
Front Facet fuel pump powered by the original FI fuel pump wire at bulkhead- worked fine when removing old engine. When plugging everything back together I've lost power to the fuel pump- when jumping the wire directly to a battery it's fine. Also when checking power in the relay board, which worked fine a month ago with the OEM engine, the power pin doesn't get 12V with the ignition on. Changed the fuel pump round relay though nothing was wrong with the old one a month ago. Been screwing with this for several days and it's driving me nuts. Sure it is something simple but what the h*ll am I missing???????? |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,117 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
I'll try and simplify this- swapping engines in my '73 2.0 which I've had for 25 years (and known since new) from my '71 which I've had since new. The "1.7" has been extensively modded over the years and is a better engine than the OEM '73. Has Webers and Webcam. Front Facet fuel pump powered by the original FI fuel pump wire at bulkhead- worked fine when removing old engine. When plugging everything back together I've lost power to the fuel pump- when jumping the wire directly to a battery it's fine. Also when checking power in the relay board, which worked fine a month ago with the OEM engine, the power pin doesn't get 12V with the ignition on. Changed the fuel pump round relay though nothing was wrong with the old one a month ago. Been screwing with this for several days and it's driving me nuts. Sure it is something simple but what the h*ll am I missing???????? are the 2 actual fuses working ok? contacts? |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,168 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
check the positive terminal smaller red wires for tightness
930cabman |
is the jumper in place from ground to the xxxxx location on the relay board. (not sure of the pin, will try to get a pic later)
SKL1 |
Cabman- yes the jumper is in place and was before when everything was working. As you look down on the relay board, it is in the lower left corner.
The car was converted to carbs 20 some years ago and the fuel pump wiring done at the same time. I'm not sure what wires George is talking about above, for tightness. |
930cabman |
Cabman- yes the jumper is in place and was before when everything was working. As you look down on the relay board, it is in the lower left corner. The car was converted to carbs 20 some years ago and the fuel pump wiring done at the same time. I'm not sure what wires George is talking about above, for tightness. there is a break somewhere, maybe trace the feed wire back from the pump to the relay board, checking along the way |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,839 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Cabman- yes the jumper is in place and was before when everything was working. As you look down on the relay board, it is in the lower left corner. The car was converted to carbs 20 some years ago and the fuel pump wiring done at the same time. I'm not sure what wires George is talking about above, for tightness. there is a break somewhere, maybe trace the feed wire back from the pump to the relay board, checking along the way yes I think that also ,if that's fine my experience was a bad connection in the board even after cleaning and resealing the underside...didn't last very long so jumpered a solution off the 25amp fuse and fitted a smaller fuse,did me what I needed till I replaced the board with got spare I had, cheers. |
Lo-Fi Version | Time is now: 3rd June 2025 - 03:22 AM |
