> headlight/eyebrow adjustment, where to start
hndyhrr
post May 18 2025, 10:59 AM
How do I adjust this so headlamp cover does not scrape on eyebrow.
Thanks
Renee
Replies(1 - 2)
iankarr
post May 18 2025, 11:54 AM
Remove the side cover to expose the alignment plate. There are three bolts to loosen / adjust. Make sure you remove the relay and/or disconnect the battery while you're working so your fingers don't get smashed. There's also a pivot bracket which is attaced on the fender side and you can adust that from inside the wheel well. Here's a writeup with pics...
http://www.914world.com/specs/headlight_adjustment.php
hndyhrr
post May 18 2025, 02:24 PM
QUOTE(iankarr @ May 18 2025, 10:54 AM) *
Thank you!
- Lo-Fi Version Time is now: 2nd June 2025 - 05:12 PM
