nivekdodge |
Member ![]() ![]() Group: Members Posts: 305 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region ![]() ![]() |
I'm managing to get all the things I don't like handled and I'm quite happy with the car. I do still have a shake or shimmy but not a death wobble at 60mph. I've been searching for a good thread to follow rather than just throwing parts at it. The wheel shakes a little but also I seem to feel it in the seat. Still does it in neutral downhill.Seems to leave with a constant pressure as in a turn.
Wheels balanced, nothing out of ordinary. New turbo tie rods... Anyone document a chase? Thanks Kevin |
L-Jet914 |
Member ![]() ![]() Group: Members Posts: 349 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California ![]() |
Have you checked wheel bearing play? Lower ball joint play? Wheel/Tire assembly balance? A bent wheel can also cause a shimmy at freeway speeds. Flat spotted tires can do the same.
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,092 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
50-60 mph is almost always wheel / tire related. There is math behind why this is so but I’ll spare you the details.
1st suspect is balance - even when a shop says they are balanced - that doesn’t mean balanced to zero, just to within what ever their machine defaults to - usually 1/4 oz. Quality of balance often varies pretty drastically the skill or care of the tech doing the work. Someone may have balanced them and said they were OK. I’d have someone else double check that. 2nd would be the wheels and mounting. Rear wheels on the 914 are not hub centric. This becomes a problem if lugs are not tightened carefully and really is not fully resolved without going to hub centric adapters. 3rd suspect is tire uniformity. Google it. Short version - tires are not perfectly round nor does the tire carcass have a uniform deflection as it rotates against the road. Uniformity varies enormously across various brands of tires as well as within a brand depending on the tire construction and often depending on which plant it was made in. See video which includes description of tire uniformity. I’d first start by moving rear tires to the front while carefully mounting the rears carefully (cross torque, in multiple increments). Does that improve or degrade? After that I’d have the wheels/tires measured for uniformity by a shop that has a road force balancer (preferably a Hunter). It will cost you. But if you have a uniformity issue - this is your best chance at compensating it. https://www.youtube.com/watch?v=4OvcOX74wh0?si=AKL6EHHVCgqPbOnO |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,352 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Flat spotted tires can do the same. Been there, done that. I flatspotted the front tires on my six conversion on the tail of the dragon. Betty was following me in her car. She was laughing so hard, she almost drove off the road. I spent the whole 1100 miles driving home with the steering wheel shaking in my hands. That sucked. I agree with the test of swapping front to rear. If it gets better, have them all balanced by a high end shop. The tire monkeys at discount tire have probably never seen a lug-centric wheel in their lives, and will put too many uga duggas on the bolts, and not in a proper star pattern. Improperly torqued wheels can cause vibration with lug-centric wheels. |
dtmehall |
Member ![]() ![]() Group: Members Posts: 110 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest ![]() |
question:
doesn't it depend on the type of the wheel as to how sensitive is the described inbalance? |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,333 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
I completely agree with having a reputable shop, one that does high-end cars, do the balance. I had a slight shake in my steering wheel when I first started driving my car, after it had been aligned and all 4 wheels balanced by a shop in LA. I had the alignment re-done in Folsom and then had the tires balanced by Roger Krause Racing in Castro Valley. Nice and smooth now.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,241 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Remove the center caps yourself prior to any wheel work. The hammer and screwdriver method is destructive.
randyt914 |
Member ![]() ![]() Group: Members Posts: 124 Joined: 6-April 06 From: truckee ca Member No.: 5,832 ![]() |
if the tire and rims are truly balanced (2nd opinion needed)then look at bearings and rotors
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,136 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
Chased the same problem at the same speed for several years. Front bearings were the culprits. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 21st May 2025 - 03:23 PM |
